Renault megane car radio code needed
Username: Cinderfkinrella
Hi is it possible you could find the code for my renault megane car radio..
model no..22DC259162
T0J653
RN259F10167837
prod no.... FD0501190167837
7700434436TJ653
7700434436
would be appreciated
Regards
Username: Regrooster
Post Number: 9800
try code 6734
Just been out to try it and it is that code, now working, much appreciated.
Thank you very much.
Username: Ptrbrennan1
Galway, Galway Ireland
how can i take out radio of renault megane if i dont have the proper keys...??
Post Number: 9858
Here is a video showing how to remove a standard radio from the dashboard.
A pair of extractors are required (available from Ebay etc ) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4
securing clips
http://www.youtube.com/watch?v=urC-4NbXvDQ
note: on some radios , these 4 holes are protected by 4 small screws. These
can be unscrewed using the appropriate size of Allen key.
how do i go about getting the code for my renaault magane radio..??..will car reg number do or engine number
Post Number: 9863
The radio has to be removed from the dashboard
Then quote the 14 character SERIAL NUMBER beginning with
RN* * * * * * * * * * * * found stamped in the metal casing.
Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
