New member Username: Giogi
Post Number: 1 Registered: Nov-11
Posted on hello does anyone know the code for renault clio sport bought in 2006? i changed battery and the tuner has been locked, thanks |
Gold Member Username: Regrooster
Post Number: 9293 Registered: Aug-08
Posted on Sorry.......this is insufficient information The radio has to be removed from the dashboard Then quote the 14 character SERIAL NUMBER beginning with RN* * * * * * * * * * * * found stamped in the metal casing. Also quote the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode If in doubt post ALL the letters+numbers on any labels or barcodes ============================================================= |
Post Number: 2 Registered: Nov-11
Posted on RNRDBD60039935 RENRDW330-05 FDO106460039935 8200 633 624 --A 8200633624T X730-SECURITY 0039935 thanks |
Post Number: 9302 Registered: Aug-08
Posted on try code 2296 |
Post Number: 3 Registered: Nov-11
Posted on it works thank you |
