Code for Clarion
Username: Mak1
Hi !
Please can you find( calculate ) the code for next radio:
Clarion PU2294A
Sn.: CL0401Y0212814
Thanks
Marko
Username: Regrooster
Post Number: 8288
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
