Want SPL
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1607
I've had 4 Eclipse SW9122's for a couple years now. One of the surrounds blew out and since Eclipse went out of business I can't replace it. I'm ready to get something with more SPL. I haven't been keeping up with car audio for awhile so I'm not sure what I need. I was considering 2 x 18" Solo-x's but I'm not really big on Kicker subs....what is comprimable as far as SPL? I have a kicker 2500 watt amp but am willing to replace it.....was thinking about the Kicker Workhorse. Thanks for your input
Username: Alonzoub
Post Number: 155
Kicker Warhorse? Idk if thats necessary.
As far as SPL goes I'd look into
Digital Designs 9500's http://www.ddaudio.com/mobile-audio/woofers/9500-series.aspx
DC Audio XL's (http://www.dcsoundlab.com/woofers.html)
Fi BL (https://ssl.perfora.net/www.ficaraudio.com/sess/utn154de17404ca020/shopdata/0050 _Speakers/0020_BL/product_overview.shopscript)
... thats all I can really think of off the top of my head.
Username: Gcs8
Atlanta, Ga
Post Number: 2048
FI BTL
AQ HD Series Sub-woofers
T3 TSNS
heard good things about DC audio's higher end subs
TC Sounds LMS Ultra 5400
Username: Redliner
Wilmington, Ma
Post Number: 5128
DD 3500's or up will work great for you.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1608
Thanks for all of the ideas. Lots to choose from but I think I will go with two Fi N318's. I like the idea of being able to order direct from the company. So if I get another KX2500.1 amp I should be goo to go, right? Thanks again.
Username: Gcs8
Atlanta, Ga
Post Number: 2049
the N3's are not for music those are for the guys that go to comps and burp one note, get the N2's and just beef them up a little.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1609
Okay. All agree?
Username: Lord_huggington
Ontario Canada
Post Number: 399
Xwhatever on the beefed N2's.
How much space & what tune?
Username: B3n07
Louisville, Ky USA
Post Number: 1198
you can use the n3s for music it just wont sound that great i think the response curve falls off to quick
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1610
Thanks for all of your help. I will go with the n2's....two of them on two 2500 watt kicker amps....ought to be sick!!!
Username: Kyle_lowe
Post Number: 1317
5kw?
be prepared to drop a ton of money into your electrical system
if not, then be prepared to fry some nice, expensive equipment.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1611
I'm running two alternators - 120A and 240A. Probably need to get another 240 amper.
Ontario Canada
Post Number: 401
The LMS Ultra isn't an SPL sub, wtf? That's the mack daddy of low distortion.
You might just want one of the subs that can take wall socket abuse, TSNS, APX/APXX, Warden, SMD, ETC...
Username: Nevertoomuchbass
2 Fi Q 12s, Mmats 3000.1
Post Number: 273
couldnt you just recone the eclipses?
Post Number: 275
but my vote is the N2. I love Fi. dont think you can get any better for the money
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1612
Recone the Eclipse? Where can I get that done? Eclipse won't have anything to do with it. I can't find a QCA anywhere.
Post Number: 276
http://fixmyspeaker.com/Products.php
maybe this site can help you
Username: B3n07
Louisville, Ky USA
Post Number: 1199
or contact fi sundown or have someone build you a reconne. i dont believe eclipse went out of business just stop dealing to the us
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1613
I put in a service request with fixmyspeaker.com. I really like the Eclipse so It would be great if I could get them fixed.
Eclipse didn't go out of business, they told me that they just don't do aftermarket anymore. I will contact fi and see what they can do. Thanks for all of your help.
Username: John253a
Post Number: 17
first things first,
Do you plane to play music with it?
How many cu ft do you have? (x" x y" x z")
How many rms is you elect system capable to handle?
How much to you want to spend?
We can recomend big spl sub but if the fit or within you budget were all wasting our time
If you have the space look at the
Digital Designs 9918Z
MTX Jackhammer
Kicker solo x
Kicker L7
The list go on......
Username: Somedonniedude
Illinois Braaap MX
Post Number: 3180
^Can the average customer even buy a 99z woofer??? and way to sh!t on DD by adding Kicker and MTX to that list
Post Number: 277
f**k mtx and kicker
Username: John253a
Post Number: 18
It all come down to budget.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1614
I'm not big on the Kicker subs. I would however consider the Solo-X but not after the options I've been given here. If I can't get the surrounds repaired then I will go with 2 of the 18" N2's. I will have to build a box for them.
Username: Drant19
TX
Post Number: 2259
no square subs....period.
Username: Hdubb
Team Revolution
Post Number: 4352
hmmmm....are you just talking a daily loud musical setup or are you talking you want to compete in an org and go all out for numbers? because the 2 are totally different. i would plan it all out. and start with electrical. good batteries and alternators are a good start. like i said. everything depends on how much power you plan to run and what frequencies you want to play lol
Username: John253a
Aust.
Post Number: 63
Idd get 1x digital Designs 9918Z 18" and power it off 2 kicker warhorse
