DVC's - 2ohm vs. 4ohm.
What produces more power? 2 DVC subs that are 2ohm or 2 DVC subs that are 4ohm?
I have a new 2 channel amp that is 200W x 2 into 2 ohm.. Would it be in my best interest to get 2 DVC subs that are 2 ohm and wire hem for a two ohm load?
Hydro
Both 2 ohm and 4 ohm subs produce the same power its just that a DVC 2 ohm sub has more wiring flexibility.When a DVC 2 ohm sub is wired in parallel it will have a 1 ohm load and if you have 2 DVC 2 ohm subs and you wire them together In parallel then you will have a 0.5 ohm load It all depends on what Type of amp u have if you have an amp thats 0.5 or 1/2 ohm stable then wire both subs together in parallel but If ur amp isnt 1/2 ohm stable or 1 ohm stable u might as well get the dual 4 ohm subs.
