Clarion code for PU-2294A
Username: Fishingbaloo
Hi All,
Please can someone Help me - I need a new code or some advice for my wifes stereo that she's been nagging me about since I disconnected the battery and guessed the wrong code
The serial No. is CL0401Y0219273
Any Help would be appreciated
Username: Hay88
PortsmouthUk
Post Number: 3535
the only CLARION code available for free (using a serial number ) from anywhere on the Internet
is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service
or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
inside your radio
Thank you
Username: Ewaadam77hotmailcom
Hi All,
Please can someone Help me - I need a code for my
Clarion radio (battery changed)
Model pu-2294a©
SN/ CL040150996442C
Bar Code C70000004253
Many Thanks
Username: Regrooster
Post Number: 7448
cormoran
Posted on Monday, June 13, 2011 - 06:39 pm:
Hi All,
Model pu-2294a©
SN/ CL040150996442C
Try code 5421
Username: Radiogeorge
Hi i need a code for my clarion radio (battery got disconnected) the barcode is unreadable but the serial number is CL0401Y0380392 and the model number is PU-2294A.
any help would be appreciated
Post Number: 7620
CLARION RADIOS
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
