Code laguna radio ????
Username: Janw
who knows my radio code ?
Renault Laguna Grand Tour 1.8 16V
Bouwjaar 2005
30-RB-NK
Chassisnr: VF1KG0M05330883596
Username: Regrooster
Post Number: 7592
Sorry.......this is insufficient information
The radio has to be removed from the dashboard
Then post the 14 character SERIAL NUMBER beginning with
RN* * * * * * * * * * * * found stamped in the metal casing.
Also post the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
