Blaupunkt code for Clio
Username: Pmodern
Hi, You found a code for my wife's Philips a year or so ago. Now her sister has lost the code for her Blaupunkt.
Serial number is BP8124W6292677
There's also FD9842 and some other numbers on there if those help?
Beer tokens via your paypal again if you can help out?
Username: Hay88
PortsmouthUk
Post Number: 3550
Pmodern
code 0012
Code Entry as Follows:
Switch Radio On - Display Shows
"Code" and then
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " ¬ " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " ¬ " Until A Beep Is Heard
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store.
Username: Pmodern
Hi, Tried 0012 but it just beeps and shows four dashed lines as though the code is incorrect. Can anyone else help out with this code?
Also anyone know how to get it back into code accept mode without disconnecting battery again?
Username: Regrooster
Post Number: 7537
If your car is a Renault then 0012 should be the correct code for BP8124W6292677
Post all the letters+numbers including the one beginning 7**********
Username: Pmodern
Hi, OK all the numbers below:
77 00 428 254 Ind.R.
FD 9842
7 648 124 391
BP8124W6292677
Post Number: 7539
Using the Renault Blaupunkt Calculator the code is 0 0 1 2
Using a different calculator for the Renault Security Code then the code for Z702 is 0 2 3 1
Please post if 0231 is successful
Username: Pmodern
OK, will give that a try and post back the result.
Cheers for all the help guys :-)
Username: Hay88
PortsmouthUk
Post Number: 3574
code is 0112 not the 0012 as i first said very sorry
