Lost code for Renault Clio
Username: Dfgunner
CadizSpain
I changed the battery and don't have a code for my Phillips radio. Can you help?
Serial: RN461FX2278151
Barcode: 7700433074Q058
Thanks, David
Username: Regrooster
Post Number: 7313
try code 9962
Username: Papadons
Melbourne, Florida USA
Hi ya.
Thank you in advance!
can you possibly help with the renaul code as:
22dc259/62f
tow678
rn259fx00300005
fd02994800300005
Tried to change out radio with a panasonic but didn't have
the proper leads and had to try to put it back! Got all 0000
on the screen
Sincere thanks.
Don
Username: Bogege
BG
Post Number: 289
Papadons try code 3382
Username: Squellie
post seem to have gone missing wonderd if anyone could help my battery went flat and lost my radio searched internet for code to no avail could anyone help code number BP026348306307 many thanks Bri
Username: Hay88
PortsmouthUk
Post Number: 3522
brian
code 5294
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press Tuning Up Button " > " To Enter
hay88
http://www.howtomendit.com/answers.php?id=416129
