Clarion code needed
Username: Bigmac
Hi need a code for my father-in-laws landrover discovery.
Clarion CRO171T0032649.
any help would be most welcomed
Username: Regrooster
Post Number: 7230
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
Username: Xanpoke
Hello. My Citroen Xantia-99 needs radio code. Is it possible with info:
C 70000004436
C 6CBN0014523
Ser. nr. 0014523
I am looking forward to your reply.
Xanpoke
Post Number: 7255
Jorma PentikA¤inen
Username: Xanpoke
Posted on Sunday, May 29, 2011 - 12:34 pm:
C 70000004436
C 6CBN0014523
Ser. nr. 0014523
try code 5664
Username: Xanpoke
Thank you very much.
