Amp RMS vs. Speaker RMS (Someone please Help!)
Username: Austin6
Post Number: 12
I am running into a delimma... I have an Amp that pushes 800 Watts RMS at 4 Ohms. I want to get 2 12's, but I cant seem to find any speakers that are less than $150 each. and have a RMS of 400 Watts at 4 Ohms.
Can I go with a speaker that is 325 WAtts RMS? or will I blow it?
Thanks in advance...
Username: Grmncrsnbr
VA
Post Number: 165
ok well here ya go there is a buy it now auction on ebay for two mtx t81244as in a box from MTX and the total after shipping is like 289 thats with 3 day shipping. These subs are 400 rms a peice. the only thing youll have to do is do some wiring inside the box in order to run the subs in parellel and the voice coils in series in order to get the 4 ohm load.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39778&item=5707708003&rd= 1
Robert J
get 2 kicker compvr sub wooferecutics has them for under a 100 bucks. they are 400rms each, and they are much better subs then mtx. you could look on ebay they probably have them cheaper on there.
