Help my ford 6000 cd is locked
Username: Theth
here is my serial number for ford 6000 cd please help
wf04xxgbb43j01299
Username: Regrooster
Post Number: 6213
Post the SERIAL NUMBER beginning with M++++++ or V++++++ found on a label on the radio casing
Username: Theth
ok but when u give me the code how would i put it???
Post Number: 6216
Ford Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate.
Username: Theth
ok i'll bring u te serial in 10 minutes thanks alot love u guys so much
Username: Theth
how do i find the serial its not when i turn on the cd player
its just a big line of letters and numbers "wf04xxgbb43j01299"
and another problem the cd player only presses on and off the other buttens dont press
Post Number: 6263
Remove it from the dashboard
Here is a video showing how to remove a standard radio from the dashboard.
A pair of extractors are required (available from Ebay etc ) but these can be made from 2 pieces of bent, wire coat-hanger or 4 small drills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4 darts.
An assistant is useful to pull the radio out whilst you are releasing the 4
securing clips
http://www.youtube.com/watch?v=urC-4NbXvDQ
Username: Theth
not that kind 6000 cd
Post Number: 6268
Find the removal instructions here then !
http://www.fitaudio.com/index.php?CategoryID=13
Username: Theth
Post Number: 7
ok ill find it but the buttens dont press what do i do
Post Number: 6269
Just take it into a Ford Dealer and they will sort it all out for you.
Username: Cosminelu84
ford focus 6000 cd serial M484428
Post Number: 6298
cosminelu84
Posted on Friday, March 11, 2011 - 01:24 pm:
Try code 1571
Username: Vgvege
HY all, i have a ford 6000 cd code prroble,m can any one help pls.
ford mondeo 2003, visteon 6000 cd S.no.- M033653
thanks
rspct
Post Number: 6506
re IVAN
FORD
try code 8139
Username: Vgvege
it works ...thanks allot reg rooster
greetings from CROATIA
Username: Joaof
Ford Transit Connect
Radio 6000CD
V234878
tks
Username: Alin11
Hi, can you help me with a code for my Ford 6000 Cd?
M441102
RYS4F-18C815-AA
Username: Bogege
Post Number: 238
Alin11 try code 6455
Post Number: 6876
JoaoF
Username: Joaof
Posted on Monday, April 11, 2011 - 11:44 am:
Radio 6000CD
V234878
Ford V Serial codes are not available for free from anywhere on the Internet as access is required to the Ford database.
Try emailing
restoredclassic@aol.com
to see if they can help
Mention this forum
Username: Panchan
help me to unlock my ford 6000cd.the s.n :V118572
Post Number: 6974
kostastz
Username: Panchan
Posted on Wednesday, May 04, 2011 - 02:35 pm:
Try emailing
Mention this forum
Username: Henk021
Hi, just bought my first car (Ford Focus) with the 6000CD RDS Stereo. But when I turn it on, it just says "Locked" on the display, cant push any buttons, just on/off. I have an old 4 digit keycode in the user manual.
Post Number: 7051
Henrik
Username: Henk021
Posted on Monday, May 09, 2011 - 03:15 pm:
It may be fully locked due to too many wrong codes
Try emailing
Mention this forum
Username: Henk021
yeah, thats what I belive... Thanks for the help
Username: Cristialbu82
hello, i need code for Ford CD 6000 S/N: V183738. thanks
Post Number: 7073
Cristi
Posted on Friday, May 13, 2011 - 10:49 am:
Ford V Serial Codes are not available for free as access is required to the Ford Factory Database.
The cheapest place I know for this code is here
www.ukbookshelf.co.uk/fordv.html
Otherwise try your Main Ford Dealer or a Radio Decoding Service
