Radio codes
Username: Gazsnag
West Kempsey, NSW Australia
Hello,
I need an unlock code for an in dash radio cassette player in a Ford KF Laser.
Any help would be appreciated
Username: Regrooster
Post Number: 6936
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
Username: Gazsnag
Hello Reg Rooster,
I do appreciate your help so far.
By markings on the radio it is a genuine Ford radio with a serial number of 1005508.
I look forward to your next reply.
Regards,
Gary
Post Number: 6947
The only calculator I have for seven digit serial numbers (with no letter at the beginning) are for old Ford radios using 3 digit codes.
This gives 514
If yours uses 4 digits for the code try 0 or 1 as the first digit
Username: Gazsnag
Hello again,
I still get an error message after trying your suggestions.
Could this be due to the vehicle being manufactured in Australia ?
Once again any further help will be appreciated.
Regards,
Gary
Post Number: 6950
Yes...Ford radios are often made by FMS for the Australian market and these codes are not available as there is no calculator software so they have to be looked up on the original Ford factory database..
Main Dealer or Radio Decoding Service only for this code
It will not be available for free from anywhere on the Internet
Username: Gazsnag
Thanks again for your help.
Looks like I save up & buy a new one.
Regards,
Gary
Username: King_louis
Ade Ekiti, Ekiti Nigeria
Can anybody help me out? I need the code to activate my Rover75 soloon car radio. The make of the radio is Apline & the serial no is AL 7RV630Y0229390.
My regards to you all
Can anybody help me out? I need the code to activate my Rover75 soloon car radio. The make of the radio is Apline & the serial no is AL 7RV630Y0229390. There is also another number that is wrtten just below the one quoted above which I don't know what it means - BOO229390A.
My regards to you all.
Can anybody help me out? I need the code to activate my Rover75 soloon car radio. The make of the radio is APLINE with PT No XQD101043PUY & the Serial No engraved on the bottom chases of this radio is AL 7RV630Y0229390. There is also another character string that is stamped just below the S/no quoted above which I don't know what it means - BOO229390A.
I'll appriciate any assistance offerred.
My best regards.}}
Post Number: 7015
re : Adebola
ROVER
Username: Galgan333
I just bought a 2003 Corsa at auction. The code supplied does not work. Can anyone please help.
It is Blaupunkt Radio cassette Type CAR 2003(F) No : 09 115 095
Part No : 7 649 200 321
Serial No : GM0203Y7448863
Perleeseee Help CODE
Username: Jthornton86
hi i have just bought a second hand peugeot 406
i have no radio code.
its a phillips radio and the numbers are
phapifw1075473
22DC594/65B
902221594651
M/CH 076018
FD0198491075473
PHI1075473
96336890 ZL 00
thanks
james
Username: Jopie66
Post Number: 7021
galgan
Username: Galgan333
Posted on Sunday, May 08, 2011 - 07:32 am:
You are asking for too many free codes
Reminder :..NO MULTIPLE CODE REQUESTS ON THIS FORUM
Single free code for personal use only
This is to prevent abuse by traders+dealers, car radio thieves and other chancers
Sorry if you are one of the honest ones !
Post Number: 7022
james
Posted on Sunday, May 08, 2011 - 10:31 am:
phapifw1075473
22DC594/65B
902221594651
M/CH 076018
FD0198491075473
PHI1075473
96336890 ZL 00
Duplicate post....Already answered
