Renault megane radio code
Username: Nicky36
Please can anyone help???
My car is a renault megane and i need the code to unlock the stereo.
Model number- 22DC277/62
Prod number- FD0804430701914
Q1719 security - not sure what that is
RN277F40701914
Would be very grateful for any help
Username: Regrooster
Post Number: 7089
Please double check this Security Number.
It should be 1 letter plus 3 digits
yours has 4 digits
Username: Nicky36
Hi Regrooster sorry i mis-read. It is Q719
Post Number: 7096
try code 9220
Username: Nicky36
How do I enter code? Sorry for being so stupid
Post Number: 7104
PHILIPS RENAULT CODE ENTRY INSTRUCTIONS
FOR CARS WITH A STEERING WHEEL REMOTE CONTROL
(Note :If you don`t have the [ A ] button then push the thumbwheel in and some will have an [ AA ] button )
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ A] button then rotate the thumb wheel for the correct first digit
Press the [ A] button then rotate the thumb wheel for the correct second digit
Press the [ A] button then rotate the thumb wheel for the correct third digit
Press the [ A] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ A] button for up to 10 seconds to store the code
IF THERE IS NO STEERING WHEEL CONTROL , THEN USE THE PRESET BUTTONS ON THE RADIO
Press the First Preset Button repeatedly for the 1st digit to be displayed
Press the Second Preset Button repeatedly for the 2nd digit to be displayed
Press the Third Preset Button repeatedly for 3rd digit to be displayed
Press the Fourth Preset Button repeatedly for 4th digit to be displayed
Then press and HOLD Preset button 6 for 10 seconds to store your code
(Note :Some radios use Preset Button 5 to store the code )
Username: Tomasz
Hi i need code for my renault megane COUPE 2001R
Please Help Me
MODEL;NR.22DC259/62T
7700434422TR961
7700434422
TOR961
RN259F10275283
PROD n;FD00401070275283
Username: Hay88
PortsmouthUk
Post Number: 3486
Tomasz
code 8008
