Ford Fiesta 4500 code please?
Username: Nath812
SALISBURY, WILTSHIRE GB
Hi,
Nightmare with this player - I have what I believe to be a right code but when I press 5 to confirm the radio just turns off and its back to the code screen again, saying its the first attempt again. If I enter a wrong code first then the right code the unit stays on for 1 second then does the same.
I wonder if a new code may work?
Serial - M220873
Ta,
Nath
Username: Regrooster
Post Number: 6951
Code for Serial - M220873 = 9739
If this is already the code you are using , make sure the Serial Number quoted M220873 is the one printed on the label on the radio casing.
Username: Nath812
Thats the one im using. Oh well I will have to stop crying and put the dashboard back together!
Thanks anyway.
Post Number: 6952
It is unusual for Ford radios to be recoded to a different number as the original codes are readily available.
Does the display show CODE and the digits being entered?
Are you entering the code correctly?
Ford Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate
Username: Ross599
Hi,
Would it be possible if you could get my code?
The serial number is M181513
Thanks!
Post Number: 7095
M181513 = 3264
