Renault Scenic radio code
Username: Sarfranco2003
Hi
Please can you provide me with the radio code of renault scenic 2002 model.These are the details of the radio
model No:22DC278/62P
TOW246
RN278F20011742
CODE BAR:8200152346TW246
PROD NO: FD0002030011742
Thanks in advance
Username: Hay88
PortsmouthUk
Post Number: 3543
Sarfranco2003
code 3767
You must hold at the end to store your code.
IF YOU DONT HAVE ¬ KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A¬} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press and HOLD button 6 to store. for 10 seconds
and on some it's hold 5 to store
Username: Vikkiboro1976
Middlesbrough
please need help,
four digit code for renault megan scenic 2002
starter motor went now asking for a Code for audio,
all details on radio are,
RN258F20059334
FDO100260059334
MODEL 22DC258/62P
TOW500
8200152345TW500
if can Help please email me code as new to site at,
wolfiekiller@live.co.uk
many Thanks victoria robertson.
