Enclosed sub box or bandpass box blueprints
I have all the specs for the speakers that i am going to use. I just need some help with creating a box . What i want is a dual 12 inch box
Subwoofer Specifications:
Power Handling: 150 Watts RMS 450 Watts Peak
Cone Material: Moisture Resistant Poly Coated Paper
Surround: Specially Treated Purple Foam Surround
Voice coil Size/Type: 1.5"/aluminum 4 layer
Efficiency: 1Watt /1Meter: 96 dB
Frequency Response: 35-4.5 kHz
Impedance: 4-Ohm
Magnet: 80 oz. Stronium
T Yoke: Bumped and Vented
Mounting Depth: 6-1/4"
VAS (cu. Ft.): 3.47
Fs (Hz): 32
Qts: .445
X Max (mm): 4.8
Sealed Enclosure: 1.2-2.5 cu. Ft.
Vented Enclosure: 3.0-6.0 cu. Ft.
Port Diameter/Length: 4"/5.5"-11.8"
http://www.carstereo.com/help2/Articles.cfm
jim
i need blueprints for a two 12 box for a 2001 camaro?
i need blueprints for a two 12 box for a 2001 camaro? if any body has them please e mail them to me!!
thanks!
i need blueprints for 12" subs for a truck and a box for 4 6 1/2 & 2 6x9's in tha same box.
i need blueprints for a ported box that will hold two 500 watt 12" pioneers that need 3 cubic feet between the two of them. the box is going in my trunk that has lots of space.
i have 2 12" L5 solo barics and need blueprints for a vented box. my max dimensions are 56"w x 16"t x 10"d on the bottom and 8"d on the top. i really just need help on the vent portion.
Jon_Gud@hotmail.com
PaypalWorks
I need
I want
Gimme
Gimme
Gimme for free
WAAAAAAAAAAAAAAAA!
