Code for radio Honda
Username: Jaclin44
Can anyone help me out with the anti theft code for a 2002 Honda accord? Please!
Username: Regrooster
Post Number: 6239
HONDA RADIOS.................IMPORTANT NOTICE
PLEASE READ BEFORE POSTING ANY CODE REQUEST
If you CANNOT find a code written on the radio or on a card in the glovebox (or similar "hidden" place ) then please read on
Please note:
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PANASONIC
PIONEER
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT.
These will have a Serial Number beginning with BP and another number beginning with
7 *** *** *** found on a label on the radio casing
UNFORTUNATELY ... NO OTHERS !
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If you can supply all the correct details, then they will be able to supply your code for free.
Otherwise you will have to try your HONDA Main Dealer or a Radio Decoding Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
