Radio code renault
Username: Iceman6
Hello. I need a radio code to my Renault Scenic.
On the radio is write:
model NO 22DC280/62R
TOJO 78
RN280F10001149
PROD NO FD 0001420001149
8200130526TJ078
8200 130 526
The car is from 2001 if You need it I hope someone will generate it
Username: Hay88
PortsmouthUk
Post Number: 3230
Iceman6
code 7967 hold at the end to store
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Press " " On The Stalk Control To Enter
" 0000 "
Rotate " Thumbwheel " For Correct Digit
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
