Calciumkid if TU111 CODE 5848 You must hold at the end to store the code. IF TV111 CODE 4845 IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ] button then rotate the thumb wheel for the correct first digit Press the [ ] button then rotate the thumb wheel for the correct second digit Press the [ ] button then rotate the thumb wheel for the correct third digit Press the [ ] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL press the first preset button for the 1st digit, second button for the 2nd digit third button for 3rd digit forth button for 4th digit then press and hold buttons 6 to store. for 10 seconds
