Code for Renault trafic
Username: Scottg1123
Hey every1
Can some give me a radio code for a Renault trafic
I'm not sure which numbers 2 type so I'll put all of them on the side
Of the radio
8200354519T R757-security
RNRD8260096827
RENRDD200-09
BS0006160096827
0096827
BT2
That's all the numbers I can see any help appreciated
Username: Hay88
PortsmouthUk
Post Number: 2945
Scottg1123
code 8283
I put the code in but it keeps bleeping? Is there
Something I'm doing wrong?
Username: Hay88
PortsmouthUk
Post Number: 2947
Scottg1123
YOU MUST HOLD AT THE END TO STORE THE CODE.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE " Then " 0000 "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press and hold preset " 6 " To Enter
Thanks Hay88 worked perfect!
