Hi There, After renewing the battery, then spending fruitless hours trying to obtain my Renault's code without success, I find out from a friend that there's actually people out there willing to help out simply 'cos they can - how refreshing! It's an 'R' plate Renault Laguna. It's Philips radio's serial no. is: RN459FV8015357 Bar code no. is: 7700 426 482 L073 If any more info is required please just let me know. Any help with unlocking it's code would be greatly appreciated. Many thanks - Ian.
your code 3918 you must hold at the end to store the code. Code Entry as Follows:
Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " " Until A Beep Is Heard
Crikey, but that was quick! Thanks Hay88, I'll give that a try as soon as the Mrs gets back with the car. Big thanks to you (and all the others who take the time to reply!) it is truly appreciated. Regards - Ian.
