Radio code renualt scenic 2002
Username: Mcvey
vin vf1jaodo527318723
Username: Hay88
PortsmouthUk
Post Number: 2645
you need to remove the radio.
they are too small holes each side of the radio
use an old metal coat hanger 4 darts or very small screwdriver or long nails.
put into holes about 4-5cms and push outwards sideways
and carefully pull radio forward.
you must do the holes on each side at the same time
Then post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
off of the radio
Username: Regrooster
Post Number: 5508
Remove the radio and post the radio make+model plus ALL the letters+numbers on any labels, barcodes or stamped in the metal casing
Username: Mcvey
model:22dc278/62r
bar:8200150474tp585
product:fd0202270013605
top585
rn278f20013605
this is all thats on radio..thanks
Username: Hay88
PortsmouthUk
Post Number: 2663
Mcvey
code 0408 you must hold at the end to store the code.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Press " " On The Stalk Control To Enter
" 0000 "
Rotate " Thumbwheel " For Correct Digit
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
