Renault laguna extreme 2003
Username: Sezzie69
Spalding, Lincs Uk
hi, battery was disconnected & now ive lost my radio, how do i find out wat the 4 digit code is? thanks
Username: Hay88
PortsmouthUk
Post Number: 2482
you need to remove the radio.
they are too small holes each side of the radio
use an old metal coat hanger 4 darts or very small screwdriver or long nails.
put into holes about 4-5cms and push outwards sideways
and carefully pull radio forward.
you must do the holes on each side at the same time
Then post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
off of the radio
Username: Sezzie69
Spalding, Lincs Uk
many thanks i'll post as soon as i have them.
