Renault clio radio "safe"mode
Username: Davobur
Hi just received code to unlock radio however radio is in safe-mode.I have removed radio,will it reset itself or do I have to re-install it?
Username: Hay88
PortsmouthUk
Post Number: 2319
leave it turned on untouched until it resets itself
can take few hours.
Username: Alex1211
Hi i have radio that needs decoding i would be greatfull if some one could supply me with a code.
its a Renault Clio
model no. 22DC278/62B
TOV 132
RN278F20116627
PROD NO. FD0202020116627
Username: Hay88
PortsmouthUk
Post Number: 2323
Alex1211
your code 4810 you MUST hold at the end to store code.
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
Username: Davobur
thanks hay88 radio now ok but not accepting the code I bought on-line! Can anyone help?
BLAUPUNKT in 99 clio
BP8124R6292371
FD9842
77-00-428-254-8763
7-648-124-391
(e1) 021253
Username: Hay88
PortsmouthUk
Post Number: 2369
Davobur
your code 0406
Username: Davobur
hay88,
Many thanks,code worked perfectly.wished I had discovered you and this forum weeks ago and thereby avoiding downloading code-breakers on-line which didn't work anyway!
Once again many thanks,
Davobur.
