Need code Becker 4digit for BMW 3series 1997
Username: Z3r0
Banten Jakarta
Can anyone help me, I forgot the code and I dont get the manual book when I buy it, there is only a barcode on the tape itself..
can anyone help me? the barcode is 213011830952471316.
please reply to this thread.. thx b4.
Username: Hay88
PortsmouthUk
Post Number: 2330
Z3r0
please post the number that is stamped in to the metal casing on the radio.
Username: Hay88
PortsmouthUk
Post Number: 2331
Z3r0
2130/11830952/471316
if the last four digits 0952 then try code 5027
if the last four digits 1316 then try code 7675}
Username: Z3r0
Banten Jakarta
Thanks hay, I will try the code asap after the WAIT in my becker is finish.
But I wonder why it hasn't been dissapear from yesterday.. @.@
Username: Hay88
PortsmouthUk
Post Number: 2333
if it AUVS/MONZA = Please note that code entry is only possible when the display shows "CODE". If the display shows " WAIT " then the unit may be codelocked. If this is the case, leave it switched on for up to two hours and a further attempt at code entry should be possible
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Enter CODE in the order it is read - eg:
For Example, To Enter Code 1234
Press Preset 1 then 2 then 3 then 4
If the correct code number is now shown
Press Tuning Up Button " ^ " To Enter
Username: Z3r0
Banten Jakarta
Ok, now my display is already CODE, but the code U gave me is wrong..
I am sorry for being impolite because asking so many question, but is there are another code?
Im desperate right here..
Username: Hay88
PortsmouthUk
Post Number: 2337
Z3r0
please post the number that is stamped in to the metal casing on the radio the first one you posted is far to long
Username: Z3r0
Banten Jakarta
i don't see any other number than the barcode on my tape..
in which side is it?
should i remove the tape from the car first?
Username: Z3r0
Banten Jakarta
I plan to change the becker tape for another one if this doesnt work, but if I remove the becker from my car while the code is still missing can the audio came out although I use another tape?
Username: Hay88
PortsmouthUk
Post Number: 2339
yes remove then you will find it stamped in to the metal casing on the radio
