Radio code for renault scenic
Username: Marx
England
hi,
i recently bought a renault scenic and have been unsuccessful in entering the code supplied by the vendor (he too could not get it to work when he owned the car).
i have noted down the serials e.t.c. and have listed them below, hope someone can help.
Model No 22DC259/62P
TOS919
RN259F10224011
Prod No FDO401060224011
7700434424TS919
thanks in advance.
mark
Username: Hay88
PortsmouthUk
Post Number: 1996
Marx
your code 7065 you must hold at end to store code.
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
Username: Marx
England
thanks for that. this is the code that i already have so will follow your instructions tomorrow and let you know how i got on.
p.s. when radio is switched on we get a radio station but with intermittant bleep then radio goes off and code is displayed on the clock
Username: Hay88
PortsmouthUk
Post Number: 1999
Marx
you must hold at end to store code it should sort it.
Username: Sahkari
Hello!
I need code my scenic radio
Model: RENRDW131-10
RNRD0350327520
Prod no: FD0905380327520
8200300858tx806
Username: Hay88
PortsmouthUk
Post Number: 2000
Sahkari
your code 2180
Username: Vilmerx
Hello hay88
I need some help with my radio. The battery has been disconectet.
Do you have a code for my model.:
RN449FW4115311
Thanks
Sorry for my english, i am from Denmark
Username: Hay88
PortsmouthUk
Post Number: 2005
Vilmerx
you nee to post the number from below the main fat barcode some thing like 7700xxxxxt123 or the security code.
Username: Marx
England
hex
thanks for the advice, followed your instructions and code went in sweet as a nut.
you are a star.
mark
Username: Regrooster
Post Number: 5258
Morten
Username: Vilmerx
Posted on Friday, September 24, 2010 - 07:37 am:
Hello hay88
RN449FW4115311
Try code 3 4 4 5
Username: Lindmon
Hi
Would you be help me find radio code for my renault scenic RN278f30047923
Thanks in advance
Linda
Username: Hay88
PortsmouthUk
Post Number: 2017
Lindmon
you need to remove the radio.
they are too small holes each side of the radio
use an old metal coat hanger 4 darts or very small screwdriver or long nails.
put into holes about 4-5cms and push outwards sideways
and carefully pull radio forward.
you must do the holes on each side at the same time
Then post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
off of the radio
Username: Lindmon
Hi
fd0303200047923 and t0836 model 22dc278/62r rn278f30047923 main barcode 8200150474td836
thanks a million
Post Number: 5292
LindMon
Username: Lindmon
Posted on Monday, September 27, 2010 - 09:34 am:
Hi
thanks a million
try code 3 1 8 1
Username: Bazman32
hi, i have a renault scenic. i done the 2 & 5 button. radio working but beeping. how do i reinsert the code. also i need a code for radiosat 4000 7700426414t814
Username: Hay88
PortsmouthUk
Post Number: 2204
Bazman32
quickest way battery disconect
7700426414t814 = 6148
Username: Nikus
can u help me of my scenic redio, i lost my code
model no. 22DC258/62P
tor 134
RN 258F10000320
prod no FD0001510000320
8200152345TR134
thanks
Username: Hay88
PortsmouthUk
Post Number: 2212
Nikus
your code 8853
