Ford radio code
Username: Ladydangermouse
can anyone help me unlock my ford focus radio serial number m290712 would b sooo happy
Username: Hay88
PortsmouthUk
Post Number: 2026
Ladydangermouse
your code 4104
i punched that in and nothin
Username: Hay88
PortsmouthUk
Post Number: 2028
m290712 = code 4104 how to enter below.
Late Four Digit Ford Radio Codes (no SELECT button)?
ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc
Switch the radio on and the word CODE should appear in the display
Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter.
i just wanna say it worked and u r one nice person...i hope u win the lottery 1 day ..thanx again, drivin to work will b a pleasure again
Username: Kenbill
Hello
My 6000CD is locked since I changed car battery.
Seriel no M030064
Can anyone help me with the code please?
Username: Hay88
PortsmouthUk
Post Number: 2029
Kenbill
your code 8603
Username: Kenbill
Works great!
Thanks alot!
Username: Brahim_75
Seriel no M030236
Username: Bonus
@ibrahim
Try 6861 .................
Username: Brahim_75
for my 6000dc is good tanck you.
my friend need the code for 5000RDS ,Seriel no M377260
Can anyone help with the code
tanck you
Username: Regrooster
Post Number: 5306
ibrahim
Username: Brahim_75
Posted on Wednesday, September 29, 2010 - 04:59 pm:
Try code 4 5 9 6
Reminder :NO MULTIPLE CODE REQUESTS ON THIS FORUM
Single free code for personal use only
This is to prevent abuse by traders+dealers, car radio thieves and other chancers
Sorry !
Username: Brahim_75
ok i understand .. tanck you.
Username: Urbanbigp
could someone please help me with my ford 4500 key code just got new timing belt fitted and is asking for a key code the serial number is m126550
Username: Hay88
PortsmouthUk
Post Number: 2043
Urbanbigp
your code 8038
Username: Urbanbigp
Thank you working again
Username: Dipool
hi can you help me The serial number is: M003858
thanks
Username: Hay88
PortsmouthUk
Post Number: 2127
Dipool
your code 4473
