Help needed for phillips code
Username: Bugsy
battery disconnected on renault phillips cd player and need a code....
if anyone can help it would be greatly appreciated
the wrting on the stereo from top down
RADIOSAT 6000
7700 426 484 G834
Phillips 22DC4479/62
9022 214 79629
PA5, 4*15W, RDS
FD 07 98 14 9028140
Model no: 22DC479/62
Prod No: FD 0798149028140
code gravage 9028140
Thanks for your help
Username: Hay88
PortsmouthUk
Post Number: 2010
Bugsy
your code 5541 you must hold at end to store code.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Press " A " On The Stalk Control To Enter
" 0000 "
Rotate " Thumbwheel " For Correct Digit
If the correct code number is now shown
Press And Hold " A " Until A Beep Is Heard
Username: Bugsy
thank you for that, that was fast!
i will check it out and let you know
many thanks
Username: Bugsy
thank you, that worked a treat!
