Archive through September 17, 2010
Username: Regrooster
Post Number: 3835
dewan
Username: Dewan
Posted on Wednesday, May 12, 2010 - 09:11 am:
Hi, Please help!!!!!!!!!!!
I need code for:
Blaupunkt
NO.:90 532 620
Type: car 300 (D)
7 645 852 320
GM1300V6425576
Try code 2831
Username: Gpf
I need code for:
Blaupunkt
NO.:90 532 620
Type: car 300 (D)
7 645 852 520
GM0300V6089818
thank you
Post Number: 3991
GPF
Username: Gpf
Posted on Thursday, May 27, 2010 - 02:36 am:
I need code for:
Blaupunkt
NO.:90 532 620
Type: car 300 (D)
7 645 852 520
GM0300V6089818
Try code 7889
Username: Gpf
Reg Rooster
Many thanks
work it
Username: Neman69
how much i have to wait if say "6 safe"?
i wait for 25 min and didnt show - - - -
tomorrow i will see my serial and ask for code
many thx
Username: Hay88
Post Number: 1028
To give you some idea of how long you'll have to wait before you can attempt re-entering the code if you do get it wrong:- (and by wait, that means having to leave the key in the ignition, turned to position one, and the stereo switched on as well)
Attempt 1 - wait 10 secs. (Display shows 10SAFE)
Attempt 2 - wait 10 secs. (Display shows 9SAFE)
Attempt 3 - wait 10 mins. (Display shows 8SAFE)
Attempt 4 - wait 20 mins. (Display shows 7SAFE)
Attempt 5 - wait 40 mins. (Display shows 6SAFE)
Attempt 6 - wait 80 mins. (1 hr 20 mins) (Display shows 5SAFE)
Attempt 7 - wait 160 mins. (2 hrs 40 mins) (Display shows 4SAFE)
Attempt 8 - wait 320 mins. (5 hrs 20 mins) (Display shows 3SAFE)
Attempt 9 - wait 640 mins. (10 hrs 40 mins) (Display shows 2SAFE)
Attempt 10 - Time for the bin. (Display shows 1SAFE)
Username: Neman69
ok thank you very much tomorrow i will see my serial number.
what else i need to write you so you can find a code?
many thanks
Username: Hay88
Post Number: 1030
BPxxxxyxxxxxxx found stamped into the metal casing and 7xxx xxx xxx number
Username: Adams501
Hi, can you please help me with my radio? I need a code for :
Type: CAR 300 (D)
Serial: GM0300V6192576
Part No.: 7645852520
NO: 90 532 620
THANKS IN ADVANCE
Username: Misha88
Kiev
Post Number: 106
Hello your code of radio 7312
write to me on
magnitola2010@rambler.ru
after his verification
Username: Neman69
ok here it is
blankpunkt car 300
serial: GM1300T6141473
part no.:7645852320
many thanks
Username: Hay88
Post Number: 1055
Neman69
try code 6567
Username: Neman69
ok i will let you know if works
if not i will be on "5 safe" )
thx a lot
Username: Neman69
thanks man it works
you are the best
Username: Cellline
hello,
can i have the code for:
GM0300W5160727
7 647 852 320
90 532 620
thank you
Post Number: 4105
david
Username: Cellline
Posted on Wednesday, June 09, 2010 - 12:22 pm:
hello,
GM0300W5160727
7 647 852 320
90 532 620
thank you
Try code 8728
Username: Cellline
I have only 1 2 3 4 5 6 on the post!!!!????
Thank you
Post Number: 4111
BLAUPUNKT CAR300 Code Entry Instructions
Switch the ignition key ON
Press and hold AS button * and the ON button at the same time
Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed
Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed
Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed
Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed
If the display now shows the correct Code number then
Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
Username: Alex_sm
Car 300 (E)
GM 0300 w 8501879
No. 90 533 422
Post Number: 4125
ALEX_SM
Username: Alex_sm
Posted on Friday, June 11, 2010 - 08:04 am:
Car 300 (E)
GM 0300 w 8501879
No. 90 533 422
Try code 7 0 2 2
Username: Alex_sm
Thank you for code.I have dump eeprom.
WHERE IS CODE LOCATED, AND HOW DECODE IT?
THANKS
Username: Neman69
does anybody maybe know if i change my car radio (blankpunkt car 300- Opel Astra) with other will stil work display above who shows clock and temperature becouse car radio and that display are connected.
thx
Username: Redcliffs
We took our car in to have a new engine installed and not surprisingly they detached the battery, so we need the code for the radio. Its a
Car 300 (D)
GM1300T5901254
No. 90 532 620
Much appreciated.
Post Number: 4320
RJC
Username: Redcliffs
Posted on Tuesday, June 29, 2010 - 11:36 pm:
Car 300 (D)
GM1300T5901254
No. 90 532 620
Try code 1 1 6 9
Username: Monptiange
Type: CAR 300
Serial: GM030MY5839342
NO: 90 533 422
THANKS IN ADVANCE
Post Number: 4371
MONPTIANGE
Posted on Tuesday, July 06, 2010 - 03:29 pm:
Type: CAR 300
NO: 90 533 422
Try code 8 8 9 4
Username: Liudas
Hello, could you help me with CAR300(F) unlock code
it's 7 640 852 520
s.n. GM030M33829890
no. 24 455 376
Thanks!
Username: Hay88
Post Number: 1341
Liudas
try code 4883
Username: Vovan77
Hi, everyone I have the same problem, cuold anyone help me with code?
CAR 300
GM1300T5820417
7 645 852 320
Username: Christhevillan
Hello any help with my radio please.
bmw buisness
S/N PH7950 Y1308260
Many thanks.
Username: Hay88
Post Number: 1348
Vovan77
try code 8141
Username: Hay88
Post Number: 1349
Sorry ...not in my database
Christhevillan
Try emailing
restoredclassic@aol.com
to see if they can help
Mention this forum
Cheers for trying mate.
Username: Vovan77
hay88 Thanks alot, it is alive )
Gracias !!!
Username: Colkean
Hi, hope someone can help me with a code? I have:
CAR 300 (D)
GM 0300 T5474419
7 645 852 520
No: 90 532 620
Username: Hay88
Post Number: 1482
Colkean
try code 3655
Username: Donatas
Hii, can anyone help me, i have Opel vectra and ... the rest is typical, remove battery and now code needed!!!
Type: CAR 300 (F)
Serial: GM030MY5736228
Part No.: 7649852520
NO: 90533422
THANK YOU VERY MUCH FOR HELP!
Username: Hay88
Post Number: 1492
Donatas
try code 4237
Username: Jesperms
Hi,
I also need some help to unlock my raido after battery change.
Blaupunkt CAR 300 (D)
S/N: GM0300V6144219
BR
Jesper
Username: Hay88
Post Number: 1545
Jesperms
try code 8978
Username: Spoliator
Hello, can you help me with my radio please? I need a code for :
Type: CAR 300 (E)
Serial: GM0300X9692103
Part No.: 7 648 852 320
NO: 90 533 422
Many thanks!
Post Number: 4562
Spoliator
Username: Spoliator
Posted on Wednesday, July 28, 2010 - 09:30 am:
Type: CAR 300 (E)
NO: 90 533 422
try code 6 5 0 1
Username: Spoliator
Thanks Reg Rooster, it worked fine!
Username: Falcon78
Hi, can anyone help me, i have Opel. Remove battery and now code needed!
Type: CAR 300 (D)
Serial: GM0300S2278607
NO: 90532620
Username: Hay88
Post Number: 1553
Falcon78
try code 6647
Username: Aaalan
Hi,
same old problem here, in need of a code for:
GM 90 383 441
Tnx a lot!
Username: Dugliss
Hi, any chance of a code for my Zafira radio cassette please?
GM030M 23094293
Thanks
Username: Hay88
Post Number: 1562
Dugliss
please post the 7xxx xxx xxx number also thanks
Username: Dugliss
Sorry, it`s 7 640 852 520
Username: Hay88
Post Number: 1564
Dugliss
Try code 4383
Username: Dugliss
Excellent, thanks very much
Username: Dj_danny82
Please help!
Need code for:
Blaupunkt car 300 (F) 2F2
No:24 455 376
7 640 852 320
GM030041517410
Made in Portugal
Thanks!!!
Post Number: 4677
Danny
Posted on Tuesday, August 03, 2010 - 05:45 pm:
Please help!
Need code for:
No:24 455 376
7 640 852 320
GM030041517410
Try code 3 0 0 2
Username: Juju83600
hi
GM1300V6485161
7 645 852 320
CODE ?
Post Number: 4690
julien
Username: Juju83600
Posted on Wednesday, August 04, 2010 - 05:05 pm:
hi
GM1300V6485161
7 645 852 320
try code 1 9 0 4
Username: Adam63tj
Hi, I've lost the radio code for my Astra Blaupunkt 300 radio.
Ser No. 90 553 422
GM0300X9361249
Any help in finding the code would be much appreciated. Thanks.
Username: Hay88
Post Number: 1577
Adam63tj
try code 8113
Username: Adam63tj
thanks hay, but the radio only has numbers 1-6, so that can't be it.
Also when I enter a code, the only number that actually shows is 0. ie. when I push the 1 button, on the screen it enters 0. Same when I push button2,3,4 etc.
Any ideas?
Post Number: 4714
adam63tj
Username: Adam63tj
Seek further free advice here
Mention this forum
Username: Petrunjela
Hello! I need your help please!
I need code for my radio
No.90 532 620
GM0300T5294274
7 645 852 520
I would appreciate your help
Username: Hay88
Post Number: 1658
Petrunjela
try code 8806
Username: Lukasik
Hello!
Can someone help me to get the code for...
CAR 300(D)
GM0300T5514813
7 645 852 520
no. 905320620
Thanks!
Post Number: 4922
lukas23
Username: Lukasik
Posted on Saturday, August 21, 2010 - 08:20 am:
Hello!
CAR 300(D)
GM0300T5514813
7 645 852 520
no. 905320620
Try code 3 5 9 7
Username: Mkilppis
Hello,
lost my Blaupunkt 300 code, I would be really happy if someone can help me
GM0300T5173064
7 645 852 520
no: 90532620
Post Number: 4927
mkilppis
Username: Mkilppis
Posted on Saturday, August 21, 2010 - 02:01 pm:
Hello,
GM0300T5173064
7 645 852 520
no: 90532620
Try code 3 7 0 1
Username: Mkilppis
Reg Rooster,
thanks a lot, it really worked!
Need to remember you also later
Username: Alex71
Help pls!!!
300T5865247
7 645 852 320
Blaupunkt Car 300(D)
> no: 90532620
Thanks
Post Number: 4952
Alex
Username: Alex71
Posted on Sunday, August 22, 2010 - 01:07 pm:
Help pls!!!
300T5865247
7 645 852 320
> no: 90532620
Try code 9 3 8 0
Username: Aditano
Hi
Like a lot of other people, bought Vauxhal Astra and discovered the radio didn't work. They had obviously disconnected the battery and there is no code for it.
It a Blaupunkt Car 300(E)
Serial No. GM0300X9671812
Part No. 7648852320
90 533 422.
Much appreciate if someone could help me out.
Thanks. Armando.
Post Number: 4957
Armando
Username: Aditano
Posted on Monday, August 23, 2010 - 05:57 am:
Hi
Part No. 7648852320
90 533 422.
try code 3 9 9 6
Username: Ali2
Hi everyone!
I have a Blaupunkt CAR 300 radio and i lost it's code.
Here are the serial numbers, that i found on it:
No 90532620 //
7645852320 //
GH1300V6569966
Could anyone give me a code for my radio?
Thanks a lot in advance!!!
Username: Hay88
Post Number: 1665
Ali2
try code 9260
Post Number: 4984
ali
Username: Ali2
Posted on Tuesday, August 24, 2010 - 08:26 am:
Hi everyone!
No 90532620 //
7645852320 //
GH1300V6569966
Try code 9 2 6 0
Username: Dantamplin
Hi,
can you please help, brought car with Blaupunkt CAR 300 radio, didn't think to check code...
No 90 532 620
7647852320
GM 0300W5343733
be much obliged...
Username: Aaalan
Hello!
I need some help for a code too, mine are:
GM 90 383 441
90541344
TNX!!
Post Number: 5007
a-a-alan
Username: Aaalan
Posted on Thursday, August 26, 2010 - 11:43 am:
Hello!
GM 90 383 441
90541344
Try emailing
Mention this forum
Post Number: 5009
dandare
Posted on Thursday, August 26, 2010 - 10:15 am:
Hi,
No 90 532 620
7647852320
GM 0300W5343733
Try code 9 6 3 2
Username: Chesco
Hello!
Please help me find the right code for radio.
Radio type: Blaupunkt CAR300 (E) (Vauxhall Astra 2000')
Serial number: GM0300X5169508
Part number: 7 649 852 320
Thank you so much!
Username: Hay88
Post Number: 1680
Chesco
try code 7453
Username: Marekomas
Can you help with mine?
Blaupunkt car300 opel astra 2000
GM0300Y6280822
90 533 422
8 635 132 822
Thank you very much in advance
Post Number: 5035
Marekm
Username: Marekomas
Posted on Saturday, August 28, 2010 - 07:27 am:
GM0300Y6280822
90 533 422
8 635 132 822
Try Code 8 3 4 9
Username: Maxxiemax
hello
blaupunkt car300 opel zafira 2001
GM0300T5309733
90 532 620
7 645 852 52thanks
Username: Hay88
Post Number: 1703
Maxxiemax
try code 0019
Username: Maxxiemax
maestro buen trabajo
Username: Alexsss8888
hello
blaupunkt CAR 300 (E) opel vectra b 1998
GM0300W6757371
90 533 422
7 648 852 320
thanks
Username: Hay88
Post Number: 1762
Alexsss8888
try code 0590
yes!!!!!
Many thanks!
You very much have helped me
Username: Hard_target
i need code for holden cute blaupunkt 6 disc changer
type : sys 3b-ss
No : 92 112 088
Username: Hay88
Post Number: 1775
Hard_target
please post the main BP2250xxxxxxxx can be found stamped in to metal casing
BP2250 4 3408232
Username: Hay88
Post Number: 1777
Hard_target
try code 3075 / 5413
if still not working please look for a number something like 7 xxx xxx xxx
i have numbers from 1-6 only
the other number :
7642250528
Username: Hay88
Post Number: 1778
Hard_target
try code 5413 if still not right then
Try emailing
Mention this forum
Username: Jimmydog
Anybody help with my BP car2003 code following flat battery?
GM020338335240
7649200321
09 115 095
are all numbers I can find.... Cheerz
Username: Hay88
Post Number: 1792
Jimmydog
try code 8053
Username: Jimmydog
thanks hay,
all up & working fine...
nice one
Username: Tiron_ionel
Hi,hay88
need a code for my radio
Type: CAR 300 (E)
No.: 90 533 422
7 648 852 320
GM0300X9508683
Thank you
Username: Hay88
Post Number: 1808
Tiron_ionel
try code 6304
Username: Fkusha
Type: CAR 300 (d)
No.: 90 532 620
7 647 852 320
GM0300w5173598
Thank you
Username: Hay88
PortsmouthUk
Post Number: 1931
Fkusha
try code 5291
