Renault clio mk2 code please
Username: Hazharry
Hi, I have recently changed the battery in my clio and now need a code for my cd player.
22dc279/62f
Fd0100030025762
Rn279fy0025762
T0j811
8200029541
I am not very good with electrical things so just copied all codes down, I hope someone can help me as I need it urgently.
Many Thanks
Username: Hay88
Post Number: 1824
Hazharry
your code 6336 you must hold at end to store code.
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
Username: Hazharry
Worked a treat.
Thanks very much
