1998 Renault Clio - Radio Code Phillips Radiosat 6000
Username: As169338
Do you have the radio code for:
Renault Radiosat 070
7700433070
Phillips: 22DC481/62
902221481629
FD 1299289224470
Model: 22DC48162
Many thanks in advance
David
Username: Hay88
Post Number: 1796
As169338
please post the missing letter and three digits off the end of 7700433070xxxx can be found below the main fat barcode.
Username: As169338
I think that is the info ....
Serial: RN481FFX9224470
7700433070F273
Once again - thanks for your help.
Username: Hay88
Post Number: 1813
As169338
your code 5157 you must hold at end to store code.
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
Username: As169338
Many thanks for your effort Hay - Much appreciated.
Entered the deatils as above and now the Dash LED display just say's 'CODE' and nothing can be entered almost as though its been frozen. Turned everything off - Disconected rear leads - reconnected all and message 'CODE' still appears. Cannot enter anything with sidestick etc...
Any advice at all?
Username: Hay88
Post Number: 1815
please check > 7700433070F273 = 5157
leave turned on untouched until it resets itself.
try pressing {A} button then rotate thumb wheel
