Archive through September 08, 2010
Username: Dakics
@hay88,
thank you so much, you rule!
Username: Regrooster
Post Number: 4573
Sanita
Username: Zvanc
Posted on Thursday, July 29, 2010 - 03:02 pm:
Philips 22DC593/62L
RN593FV4199148
try code 9 3 9 6
Username: Moms_tuner
Hi there 2004 Honda Civic cd/ radio s/n 27076435
can you get codes for this ?
Thanks !
Username: Looping
Hi , I need a code for a GRUNDIG WKC 1703, serial is GR0898S0122457 , thanks !
Post Number: 4591
loopinglooping
Username: Looping
Posted on Saturday, July 31, 2010 - 03:58 am:
Sorry ...not in my database
Try emailing
restoredclassic@aol.com
to see if they can help
Mention this forum
Post Number: 4592
Jackie
Posted on Thursday, July 29, 2010 - 06:47 pm:
HONDA RADIOS.................IMPORTANT NOTICE
PLEASE READ BEFORE POSTING ANY CODE REQUEST
If you CANNOT find a code written on the radio or on a card in the glovebox (or similar "hidden" place ) then please read on
Please note:
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PIONEER
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT.
These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing
UNFORTUNATELY ... NO OTHERS !
So you will be wasting your time posting code requests here for any other make.
BLAUPUNKTS ONLY with a BP Serial Number
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Username: Athers
just changed battery on vectra and radio is flashing for a code
havnt got the code card , there is a 4 digit code written on top of radio but it dont work
radio is - delco cdr500(e)
serial - GM1500Y9296322
please can someone help
Post Number: 4599
DELCO CODES
Unfortunately DELCO codes are not obtainable for free (using the Serial Number) from anywhere on the Internet as access is required to the original factory database which is only available to the Main Dealer or one the larger professional Decode Services.
The alternative is for your radio to be taken/posted to a Decode Service or your local Car Radio / Audio Shop who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Username: Davida
Hi, I have just changed battery on my Clio 03 and, voila', the radio has resetted.
I will be grateful for the radio code for:
Mod. 22DC278/62B
RN278F30431123
Prod. FD0403130431123
8200057681TY792
Thanks a lot in advance.
Post Number: 4609
David
Username: Davida
Posted on Saturday, July 31, 2010 - 03:02 pm:
Mod. 22DC278/62B
RN278F30431123
8200057681TY792
Try code 1 2 3 7
Username: Zvanc
it works, thanks a lot, Reg Rooster!
Username: Dsebring
Hi, if you may, i just changed the battery on my 2000 VW Jetta VR6. I need the radio code - bought the car used with no code. Thank you in advance seems you''ve helped a lot of people. lots of karma for you.
Vin# 3VWSE29M0YM003157
Radio Serial# VWZ4Z7A4050213
other writing
Premium 5
Model 1J0 035 180 B
DE P/N 09351369
Post Number: 4637
dsebring
Username: Dsebring
Posted on Sunday, August 01, 2010 - 07:05 pm:
other writing
Premium 5
Model 1J0 035 180 B
DE P/N 09351369
Sorry....Main VW Dealer or Radio Decoding Service only for this code
Username: Dsebring
Cool, I'll call the dealer in the morning. Thanks anyway.
Username: Dstyling
Can someone please help. I need a radio Code
Bought a replacement stereo for a Daewoo Kalos/Holden Barina. The stereo is Daewoo Electronics manufactured August 2005.
ID Code: TH
Part #: 96 444 822
Barcode: DE508TH03A62319
Your help would be appreciated!
Post Number: 4639
David
Username: Dstyling
Posted on Sunday, August 01, 2010 - 10:20 pm:
ID Code: TH
Part #: 96 444 822
Sorry.....Main Dealer or Radio Decoding Service only for this code
Username: Dstyling
Thanks for the info Reg. Appreciate the reply.
I am quite a novice at this. What is, or where would I find a Radio Decoding Service. I am in Australia if that helps?
Post Number: 4647
A Radio Decoding Service is a Car Radio Specialist who can connect a laptop to read the working code that is inside the memory chip (EEPROM) inside your radio using special "Dump Reading" software.
Here in the UK the local Car Radio store can often provide this service while-you-wait for £10 > £20 GBP
It can be also be carried out by mail order but this is more expensive as it will involve p+p costs.
Try a Google or Ebay search.
It might be worth ringing around your local Daewoo Dealers to see if they can provide the code for free using the their original factory database .If you have all the paperwork + can quote details of VIN /Serial No. then you may even be able to blag it for free.
Be careful about paying for a code just using the Serial Number because if it does not work , then it is unlikely that you will get any money refunded
Good luck
Username: Pastor1966
I have a Honda Element 2003.
I had the alternator worked on after owning this vehicle for 4 years.
I purchased from CarMaxx and it did not come with a manual or a code but I do have the radio serial.
Can you help?
2003 1324
Post Number: 4676
Please note:
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PIONEER
BLAUPUNKT.
Username: Bundalo
please code fiat punto CD 7 642 375 316
815 BP 237534076856
prod.nr.fiat 735 337 934
Username: Hay88
Post Number: 1581
Bundalo
try code 5361
Username: La666
Please help on Range Rover 1999 HSE
#salpv1446xa414030
Post Number: 4734
Mick
Username: La666
Posted on Saturday, August 07, 2010 - 04:57 pm:
#salpv1446xa414030
Try emailing
Mention this forum
Username: Scatic
Hi Guys,
Can anyone give me a code for my clio radio so I can drown the noise of my boyfriend out.
RN258F20302644
FD0302370302644
22DC258/62b
Thanks,
Jemma
Post Number: 4741
John
Username: Scatic
Posted on Sunday, August 08, 2010 - 05:37 am:
Hi Guys,
RN258F20302644
FD0302370302644
22DC258/62b
Try emailing
Mention this forum
Username: Florins15
I need a car code for renault scenic rx4 2001 cd player.
Please help!
Model No: 22DC279/62R
TOW008
RN279F10013747
PROD NO: FD0301050013747
BARCODE: 7700 434 427
7700434427TOW008
Username: Fratzeskos
Please....
Code for Renault Megane 1999
philips 22dc461/62t 9022 214 61626
FD 09 99 11 6063386
model no: 22dc461/62T
Prod No: FD 0999116063386
cod gravege: 6063386
Thanks
Post Number: 4756
banderas
Username: Florins15
Posted on Sunday, August 08, 2010 - 02:22 pm:
Please help!
TOW008
RN279F10013747
7700434427TOW008
Try code 3 9 6 9
Post Number: 4757
fratzeskos
Posted on Sunday, August 08, 2010 - 03:54 pm:
Please....
FD 09 99 11 6063386
Try emailing
Mention this forum
Username: Eyuptim
Hi, I've just bought an Audi A4, 1998, which I'm recommissioning. The code for the Blaupunkt Concert has been lost, and I wonder whether you could help?
Radionr: 014RUZ1Z3Y3033065
Thanks in anticipation,
Best regards,
Tim.
Username: Trevorc
Can anyone please help with the code for a Vauxhall Corsa radio?
Serial Number:- GM0670X9143612
I think it's a 22 DC670 radio and the manual has code 5944
I've just got the car and the radio wasn't actually plugged in so I don't think the code I have is valid for this radio.
Cheers
Username: Florins15
the code is not good.
please, give me another car code for renault scenic rx4 2001 cd player.
Thank you very much!
Username: Hay88
Post Number: 1595
Florins15
W008 = 3969 So please check that.
please make sure you hold at end to store your code.
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
Username: Keeleyd
Hi
Have just bought a Renault Laguna 1.9tdi sport. It is a T reg and the radio keeps saying code and then 4 zeros. The previous owner gaveme what he thinks is the code but we have put this in and it then beeps once and then goes back to saying code??
The model number of the stereo is 22DC481/62 and the number in the top left hand corner of the radio is 912 0702.
Is there anyway that you could give me the code to activiate this radio please?
Many thanks
Kd
Username: Hay88
Post Number: 1598
Keeleyd
hi post the numbers/letters from below the main fat barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i can help you
off of the radio
Username: Keeleyd
Hi
Thanks for quick response. The number you have asked us for is 7700433070W859.
Does this help??
Thanks
Username: Hay88
Post Number: 1600
Keeleyd
your code 3190 you MUST hold at end to store the code.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Press " " On The Stalk Control To Enter
" 0000 "
Rotate " Thumbwheel " For Correct Digit
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
Username: Keeleyd
Thanks
Will nip out now to try it!! Fingers crossed it will work!!
Cheers
Username: V450
Hello all,
Opel SC202B
Product No:90274453
GM0202A8540440
Post Number: 4759
v450
Username: V450
Posted on Tuesday, August 10, 2010 - 06:15 am:
Hello all,
Opel SC202B
Product No:90274453
GM0202A8540440
Try emailing
Mention this forum
Username: N_w_a_31
I need a code for a vw new beetle radio, serial # vwz9z7y5214708.
Thanks!
Username: Mustangwest
Hi I'n looking for the code for a BMW (Alpine) radio
Model C33
p/no 8888 1600 679
S/no AL 7BD0 V01 10464
Can anyone provide any assistance please?
Username: Sylwia
hi I need radio code philips renault
22dc258/62b
tog124
rn258f10034686
prod no; fd0101200034686
8200057673tg124
8200057673[--a] e2 029021
thank you !
Username: Sabinefritzroy
Hi everyone,
I'm in need a little help getting the code for my BMW 316i Business Radio Cassette
S/N # PH7850S1083467
Post Number: 4792
sabine
Posted on Saturday, August 14, 2010 - 11:10 am:
Hi everyone,
Try emailing
Mention this forum
Post Number: 4793
n_w_a_31
Username: N_w_a_31
Posted on Thursday, August 12, 2010 - 08:34 pm:
Thanks!
Post Number: 4794
fpv
Posted on Friday, August 13, 2010 - 10:37 pm:
Model C33
p/no 8888 1600 679
Try emailing
Mention this forum
Post Number: 4795
sylwia
Username: Sylwia
Posted on Saturday, August 14, 2010 - 10:15 am:
22dc258/62b
tog124
rn258f10034686
8200057673tg124
Try code 1 5 5 9
Username: Kilroy
Hi Can you help with the code for a Renault Clio?
22DC259/62F
S556
RN259F10370402
Product Number FD0501130370402
Username: Decode
POLAND
Post Number: 608
Kilroy---> code 7478
Username: Quito82
hi, i need the radio code for my VW Golf
vin# 3VWAK01H2VM074895
radio: VWZ9Z6T 3544809
thanx
Username: Hfamilydad
Hi,
I'd really appreciate you letting me have the code for my Renault Megane 2004.
MODEL:22DC277/62
RN277F40577900
FD0704280577900
Best regards
Post Number: 4836
HFamilyDad
Posted on Tuesday, August 17, 2010 - 02:46 pm:
Hi,
MODEL:22DC277/62
RN277F40577900
FD0704280577900
Try code 2 3 9 5
Post Number: 4837
miguel
Username: Quito82
Posted on Monday, August 16, 2010 - 06:15 pm:
Sorry ........Main V W Dealer or Radio Decoding Service only for this code
Username: Dedde
hi, i need the radio code for my Audi Gamma CC
AUZIZ6T0976439
7646245380
Post Number: 4843
DEDDED
Username: Dedde
Posted on Wednesday, August 18, 2010 - 02:07 am:
AUZIZ6T0976439
7646245380
Username: Milcah71
Pls help me and my autistic child, we lost the code of our Chevrolet Aveo 1.4 sedan 2007.
Im going crazy with her crying spells everytime she cant listen to her cds while im driving.
will donate for the code.
Mommy Mikee
Post Number: 4847
milcah
Username: Milcah71
Posted on Wednesday, August 18, 2010 - 06:22 am:
Mommy Mikee
This question has already been answered on June 20th (see above)
Further details are required in order to see if a code is available
copy of previous answer
Chevy do not make radios .They only affix their badge onto radios made by the large manufacturers (ALPINE , BLAUPUNKT etc).
In order to attempt to calculate your code , your radio will have to be removed from the dashboard .
Then please supply your radio MAKE+MODEL plus ALL the NUMBERS+LETTERS on ANY LABELS , BARCODES or STAMPED IN THE METAL CASING
Username: Dcartguy
Hello,
I desperately need the code for the stock radio in my 2004 Honda Civic.
Serial no: EJZ27218331
Vin no: 2HGES16664H641061
Edit: Just read your post about Honda radios. Sorry, please ignore my request.
Username: Djderek1971
Hi
My Vauxhall Vivaro Stereo is a Grundig Car 2002
Serial GM020231439920
Bar code 02 55431 0330 143992 0
Any help with the code would be really gratefully recieved
Post Number: 4856
Derek A
Posted on Wednesday, August 18, 2010 - 04:34 pm:
Hi
Sorry....Main Dealer or Radio Decoding Service only for this code
Post Number: 4857
Please note:
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PIONEER
BLAUPUNKT.
Username: Mikestpierre
I really hope you can help me with this!
VW Premium 7 Stereo from a 09 EOS,
made by Matsushita I believe..
Model: CQ-EV1467G
Stereo Serial Number: VWZ5Z7H2251193
Original Car VIN: WVWBA71F89V009921
Thanks!
Post Number: 4880
mikestpierre
Posted on Thursday, August 19, 2010 - 11:23 am:
Model: CQ-EV1467G
Sorry....Main V W Dealer or Radio Decoding Service only for this code
Username: Grishu
Hi guys, I need safe code for Blaupunkt 300 D car radio after change of alternator. 97 Opel Astra F.
90 532 620
7 645 852 320
GM1300V6578208
Thank you for your time
Post Number: 4897
grishu
Username: Grishu
Posted on Friday, August 20, 2010 - 07:05 am:
90 532 620
7 645 852 320
GM1300V6578208
Try code 0 4 5 4
Username: Joshl118
Hello
Im new Here,
Need a code for my radio if possible please?
Renault Clio 1.2 Expression 2001.
e2*98/14*0126
VF1CB05CF25860867
F043139
Please help, if these codes arent right? (as im rather confused - then please tell me where to locate this).
Thanks in advance.
Post Number: 4936
joshl118
Username: Joshl118
Posted on Sunday, August 22, 2010 - 07:09 am:
Hello
Im new Here,
e2*98/14*0126
VF1CB05CF25860867
F043139
Try emailing
Mention this forum
Username: Grishu
thank you Regrooster
Username: Lortega75
hi,
new in here!
need a code plz
rnrd6950003446
t015
ty 4 ure time!
Post Number: 5010
re : manuel / Lortega75
RENAULT
Try code 6 9 5 3
Username: Peterclose
Please can you help. need radio code for Renault Grand scenic
model number RENRDW132-10
H366 SECURITY
PRODUCT CODE FD0805190185104
OTHER SERIALS ON SIDE ARE
RNRD0450185104
8200300859
THANKS IN ADVANCE
PETER
Username: Hay88
Post Number: 1707
Peterclose
your code 4037
Username: Roadie4
Hello,
Need radio code for 1995 BMW 525i E34
Serial #: F40715616
Thank you!
Username: Hay88
Post Number: 1708
Try emailing
Mention this forum
Username: Menulius
hallo, i have lost my radio key, could anyone help me?
Model NO : 22DC279/62Z
T0X356
RN279F10129422
PROD No : FD0101290129422
i found other topic https://www.ecoustics.com/electronics/forum/car-audio/626901.html#MB about this radio, but its locked, so im writing here. please, somebody help me
Post Number: 5080
menulius
Username: Menulius
Posted on Tuesday, August 31, 2010 - 03:14 am:
T0X356
RN279F10129422
Try code 2 6 3 2
Username: Toommii
hello i am new in here,have renault laguna 99,my radio need code.
The radio is philips 22dc481/62 9022 214 81629
prod number:fd 0098359000383
barcode:770 433 070 R065. could someone help me please.Thank you very much.
Username: Hay88
Post Number: 1710
please see your other post
Username: M__to
hi
I Have peugeot 406 1997
the radio is philips 4035
PHB9037454
90222159465900
00196099037454
22DC594/65
this is all i can see
thank you
Post Number: 5136
m__to
Username: M__to
Posted on Monday, September 06, 2010 - 03:53 am:
hi
PHB9037454
90222159465900
00196099037454
22DC594/65
Try emailing
Mention this forum
Username: Cwaite12025
Hi, I really need a code for my 1999 mirage can someone help me?
MN:MR472955
Serial:99A102947
Username: Hay88
Post Number: 1780
Cwaite12025
Try emailing
Mention this forum
Username: Tiron_ionel
Hi,hay88
need a code for my radio!
Chrysler Stratus LX
part no. P5269486
issue 1
date code 0415
supplier 26777
S/N T BB AA 041 5 16370
Thank you
Username: Hay88
Post Number: 1788
Lonel
sorry not in my database
please email chryslercode@aim.com
to see if they can help.
Username: Jordy
Hi! can you help me with a radio code for my vw sport van 2007...
5Z0035119C
P/N 13703015
VWZ4Z3FN301630
Thank you
Post Number: 5140
sandra gonzalez
Username: Jordy
Posted on Tuesday, September 07, 2010 - 12:15 pm:
5Z0035119C
P/N 13703015
VWZ4Z3FN301630
Sorry...Main V W Dealer or Radio Decoding Service only for this code
Username: Angie_ghost
hi i have a renault car stereo and the battery went flat
model is 22DC259/62
other numbers are
TOV914
RN259F10189164
FD0501290189164
the nuber below the barcode is
7700434436TV914
plz help and would be much appreciate and many thanks
Post Number: 5141
angie
Posted on Tuesday, September 07, 2010 - 01:13 pm:
model is 22DC259/62
other numbers are
TOU914
RN259F10189164
FD0501290198164
7700434436TV914
You have misread one of your numbers
if TOU914 code = 5 0 1 6
If TV914 code = 4 0 1 3
thx reg but i made 2 mistakes
never mind it worked code =4013
fixed other post thanks for help
Username: Stephenjholmes
Hi
I am hoping someone can help.
I need a code for a Rover MG Stereo CD5404 MP3X
The info on the label is as follows
XQE000940PMA
VDCD3242000945
A2C53099318
CG000511000945
I hope this is enough info to find me a code.
If not I would apreciate any info that I can get about where I might be able to get it sent to for decoding.
Thanks
Steve
Username: Papalepoepie
Hi I am Papalepoepie,
I am new here because I lost my car audio code.
Can anybody help me???
RNRD0330038809/H990
Renault Scenic
Thank you for helping.
gr Papalepoepie
Post Number: 5151
Steve
Posted on Tuesday, September 07, 2010 - 03:38 pm:
Hi
XQE000940PMA
VDCD3242000945
A2C53099318
CG000511000945
Multiposted x 4 times ..........Already answered
What is the point of multiposting the same request?
Post Number: 5152
mdv
Posted on Tuesday, September 07, 2010 - 01:50 pm:
RNRD0330038809/H990
Renault Scenic
try code 2 2 3 8
Hi,
need a code,
GM PHILIPS
Type: CAR 400
No.:90 462 560
GM0400S1135715
thank you
Please can you help....
Username: Youngy18
Hi, i was just wondering if anyone could help as my renault clio 51 plate recently had an MOT where the battery was disconnected, but my radio code is not working and i was wondering if you could help me,
This is what I can see on my radio :
22DC279/62F
RN279F10154927
FD0301290154927
Under the barcode: 8200029541TD237
Thankyou
Username: Pkubicki
hi can anyone help
renault clio 1.2 campus 2007
RNRDBC70097183
RENRDW323-00
FDO507200097183
8200633621TZ750-SecurityUpload
Post Number: 5157
youngy18
Username: Youngy18
Posted on Wednesday, September 08, 2010 - 01:36 pm:
22DC279/62F
RN279F10154927
FD0301290154927
DUPLICATE Post...Altready answered
Please do NOT post the SAME request more than once
