Laguna radio beepig after code accepted
Username: Unclebuzz
managed to find my code on top of the radio (Laguna) took three tries -ERROR code flashing and beeping- and during the third; I was pressing lots of buttons, switching it on and off, then it started working.............!
BUT, now it beeps every two seconds when the radio/CD is on.
Any ideas on how to stop it beeping?
Username: Hay88
Post Number: 1776
you need to store code by hold at end.
whats your model ?
if you post the numbers/letters from below the main barcode
something like 7700xxxxxxtt123 or 8200xxxxtt123 or
the security code like Q123 or T0U123
can be found in a small box then i may be able help you
Username: Unclebuzz
Hi Hay88
After I put the full code in, I pressed the same button, (under the column) until it beeped, it then said ERROR, I switched it of and then on and it 'worked' except the 2 second beeping started......
I will post the other codes later when I get home.
Cheers
Username: Unclebuzz
@Hay88
Mod: RENRDW100-10
TOC046
RNRD013010276
Prod: FRO 103360102076
Username: Hay88
Post Number: 1799
Unclebuzz
your code is 1926 you must hold at end to store code.So try to unplug the radio then plug back in.
then turn it on,
if it say Error/CODE on the display then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
