Question about speakers and amp!
Username: Computermaniac78
If I have the following sets of speakers:
INFINITY KAPPA693.9i
and
INFINITY KAPPA50.9cs
What would be a good amp to get? Like what wattage? Or should I get 2 separate 2 channel amps? Please help and give me some amp examples! Thanks a ton!
Username: Wandaddy
Naha, Okinawa Japan
Post Number: 21
What is your budget? I think you would be fine with just 1 4-channel amp w/ 75 RMS X 4 output. Are you going to be running subwoofers as well?
I don't really have a budget, something fairly cheap but will still sound decent when I turn it up for super good songs. I hate listening to my favorite songs when they are crackly and distorted and was looking to tune up my stock set-up a little bit so that I could listen to the good stuff loud! And I will not be running a sub on it at all.
Username: Wandaddy
Naha, Okinawa Japan
Post Number: 22
Here are a few suggestions:
http://www.sonicelectronix.com/item_12020_Alpine+MRP-F300.html
http://www.sonicelectronix.com/item_11367_Kicker+08ZX350.4.html
http://www.sonicelectronix.com/item_16645_Pioneer+GM-6400F.html#tabs
http://www.sonicelectronix.com/item_19566_Rockford+Fosgate+R300-4.html
http://www.sonicelectronix.com/item_20626_JL+Audio+J2+320.4+-J2320.4-.html
All of these are decent amps and they are all under $200
Sweet! Thanks a ton! That should work to just keep my stock radio and get better speakers and an amp if I wanna be able to crank it a little louder and have it come through clear though right? (My friend just told me it won't work....I thought it would...so I'm just checking)
Username: Wandaddy
Naha, Okinawa Japan
Post Number: 23
Well if you want to keep using your stock radio, you need an amp with speaker level inputs, some of the ones I suggested have them. You should seriously think about getting an aftermarket head-unit though.
Ok, thanks a ton!
