Problem with jensen uv8020! help!
Username: Oscarbarrera
so my head unit (jensen phase linear uv8020) wont play my cd's or dvd's! .. all it says is "reading" for a long time, and then it jus say "error disk"
does anyone know what could be wrong with my my head unit, or have any ideas?? .. i would really appreciate the help
Username: Illuminator
Post Number: 5402
Can you hear the CD spinning? It's VERY possible all it has is a dirty lens. You can either 1: buy a lens cleaning CD or 2: take the unit apart enough to access the lens in the CD mech, then take a q-tip and some rubbing alcohol, dip one end of the q-tip in the alcohol and wipe the lens, then use the dry end to wipe off the excess alcohol (i.e. dry it out).
If the above doesn't work, it's a mechanical issue (bad pickup, most likely). Unfortunately, Jensen head units are fairly well-known for having CD/DVD players that go bad quickly.
thanks for the response, and yes i can hear the cd spining.
i will try to use the cd cleaner some time today, hope it works!
