Final help before purchasing 2
Username: Shopvac
Post Number: 29
Was told I would get more help in this section..so here is the thread I started at the amp section. https://www.ecoustics.com/electronics/forum/car-audio/642830.html
Ok guys I need your final expert opinion before purchasing....
First off, I am settled on buying a sundown amp, my choice for the sub...a single FI Q 12 "or" a single FI Q 15...both RMS 1000 watts dual 2 ohms.
Questions..
1. Should I buy the SAX 1200D or SAZ 1000D?
2. The SAZ 1000D have proven it's self, is there any inherent problems with the SAX 1200D which replaces the SAZ1000D?
3. I am looking for clean loud bass, should I go with a single12'' FI Q Ported or a single 15'' FI Q sealed?
4. I am located in Canada, can you suggest a good online store where I can purchase the sundown amp.?
Thanks,
Shopvac.
Username: Gcs8
Atlanta, Ga
Post Number: 1097
the 1000D is smaller...
Username: Gcs8
Atlanta, Ga
Post Number: 1098
and cheaper.
Username: Mystre
Pemberville, Ohio USA
Post Number: 314
You can purchase here: http://www.soundsolutionsaudio.com/store/categories/Amplifiers/Sundown-Audio/
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 657
I came across this,i hope it can help.
http://www.diymobileaudio.com/forum/diy-mobile-audio-sq-forum/26674-fi-q-12-vs-1 5-ported-vs-sealed.html
Username: Shopvac
Post Number: 30
Thanks guys..
