Renault megane 1998 radio code
Username: Getsmefroma2b
hello could any body be able to give me a radio code for my renault megane has recently come to me with out any of the documentation.
details are
phillips standard player
Rn449fw4183179
model no: 22dc449/62l
prod no: fd 0898284183179
any more information required then please say thank you for anyone who can help.
Username: Hay88
Post Number: 1382
Getsmefroma2b
please post the number from below the fat barcode.
something like 7700xxxxxxxt123
ah yes its 7700426414u517
Username: Hay88
Post Number: 1383
Getsmefroma2b
your code 5445 you must hold at end to store code
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
Username: Mikey75
Hello there!
Anyone who could give me the code for my Renault Laguna-01 standard player (Philips I guess)?
The specs:
Model NO: RENRDW100-10
Prod No: FD0003240074031
And below the "fat barcode" I found the number 8200247962TU314
...and a last number can be found beneath yet one more barcode:
TOU314
RNRD0130074031
A huge THANK YOU in advance to anyone who can make my 2-year old daughter happy when in the car again...
Username: Hay88
Post Number: 1385
Mikey75
your code 5691
