1996 Range Rover Radio Code
Username: Captainfast
please help! just bought a 96 range rover and no radio code, the only numbers on the radio are: PU-9836A & PRC 7618
Anyones help would be great
Username: Regrooster
Post Number: 4399
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
