Can you plese help, i need radio code of my 2001renault scenic rx4 MODEL NO;22DC279/62R Product no:FD0301070014871 RN279F10014871 AND ABOVE THAT T00968 OR T0Q968 NUMBER UNDER THE RENAULT BARCODE PART IS 7700434427 TQ968
Can you plese help, i need radio code of my 2001renault scenic rx4 MODEL NO;22DC279/62R Product no:FD0301070014871 RN279F10014871 AND ABOVE THAT there is a number : T0Q968 NUMBER UNDER THE RENAULT BARCODE PART IS 7700434427 TQ968
Posted on Tuesday, June 15, 2010 - 05:22 am: Can you plese help, i need radio code of my 2001renault scenic rx4 MODEL NO;22DC279/62R Product no:FD0301070014871 RN279F10014871 AND ABOVE THAT there is a number : T0Q968 NUMBER UNDER THE RENAULT BARCODE PART IS 7700434427 TQ968 ================================================
Please do NOT keep posting the SAME request in different threads ! It is both annoying and timewasting to the volunteers that read and answer these queries !
sorry, in fact they are not the same, I checked the number and it is T0Q968, in first post I wrote T00968 or T0Q968. I thought that would be exact and easier for getting help, thanks
Dengizzeki Q968 = 9095 HOW TO ENTER IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ] button then rotate the thumb wheel for the correct first digit Press the [ ] button then rotate the thumb wheel for the correct second digit Press the [ ] button then rotate the thumb wheel for the correct third digit Press the [ ] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ] button for up to 10 seconds to store the code
I have a renualt scenic grand, disconnected the battery lead and now i require the code for my stereo, can anyone help please! the info i got off the stereo are: RNRD4250000904 RENRDW233-10 FD0105260000904 8200367494T H438
Can anyone help me i have just got a renault scenic with no radio code. Model No. 22DC258/62P TOA326 RN258F20002298 Product Code. FD0002020002298 Bar Code. 8200152345TA326 Many thx im missing my music....
Turn on the radio and the display will show 'CODE' Use the steering controls for code entry. Press the [ ] button then rotate the thumb wheel for the correct first digit Press the [ ] button then rotate the thumb wheel for the correct second digit Press the [ ] button then rotate the thumb wheel for the correct third digit Press the [ ] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and HOLD }the [ ] button for up to 10 seconds to store the code
Hello hay88 I hope you can help me too. Before you look up my code I will tell you that my two year old twins posted coins through the cd slot and shorted the link to the dash display. If there is a way of entering the code without being able to see the display then please, dig the code out for me. If not, just tell me I need to spend £300 on a new radio. RNRD8460036121 8200550822TU786 Thanks in advance. It's a great service you're doing.
Madpearl the code 5215 you can try entering blind like this it mite go 0123456789 or 1234567890 so try FOR NO STEERING CONTROL press the first preset button 1 for the 1st digit, 6x second button for the 2nd digit 3x third button for 3rd digit 2x forth button for 4th digit 6x then press and HOLD buttons 6 OR 5 to store. for 10 seconds IF NOT GIVE IT HALF HOUR LEFT TURNED ON TO RESET. Then try 5215 button 1x5 then button 2x2 button 3x1 button 4x5 then hold button 6 to store code.}
