Looking for Code and instructions
Username: Sixiroor
Hello
I have Renault Clio 1.6 with Philips radio. My battery died and now it is asking me a code. So, Please can anyone help me to find the code I need, and how to put in. Here what I found the sticker on the radio.
Philips
Radioset 6010
Model No: 22DC461/62E
Prod No: FD 0898362006485
FD 08 98 36 2006485
this Number: 902221461622
Par-code No 77004330714 Q240
Please let me know if I miss anything. I thank any one who help me this in advance.
Username: Hay88
Post Number: 1480
Sixiroor
your code 9741 you must hold at end to store code.
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE "
Press " " On The Stalk Control To Enter
Rotate " Thumbwheel " For Correct Digit
If the correct code number is now shown
Press And Hold " " Until A Beep Is Heard
And the Radio will then Turn On
Username: Sixiroor
Hi hay88
Thank you so much. I will try and let you know the result.
Thanks again.
Username: Sixiroor
Hi Hay88
Thank you so much again, it worked and I am very happy!!
Thanks
