Radio code help please
Username: Pclegg
I need a radio code for a radio serial #2107 7165. That's for a honda accord 02 se. If more infor needed please let me know
Username: Regrooster
Post Number: 4233
HONDA RADIOS.................IMPORTANT NOTICE
PLEASE READ BEFORE POSTING ANY CODE REQUEST
If you CANNOT find a code written on the radio or on a card in the glovebox (or similar "hidden" place ) then please read on
Please note:
The majority of HONDA codes are NOT readily available as access is required to the original factory database which is not commercially available to buy
HONDA radios are made by the following manufacturers
ALPINE
AUTOSOUND
BLAUPUNKT
CLARION
KENWOOD
MATSUSHITA
PIONEER
The only Honda radio codes that are available to be calculated for free from anywhere on the Internet will be radios made by
BLAUPUNKT.
These will have a Serial Number beginning with BP and another number beginning with 7 *** *** *** found on a label on the radio casing
UNFORTUNATELY ... NO OTHERS !
So you will be wasting your time posting code requests here for any other make.
BLAUPUNKTS ONLY with a BP Serial Number
For EVERY other HONDA radio made by one of the other manufacturers then visit the website below
https://radio-navicode.honda.com
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Username: Dqueen
Hi There,
Can you please assist me with the radio code for a Corsa Classic.
Serial No: 7C0000411
Thanx in advance
Post Number: 4248
D'queen
Username: Dqueen
Posted on Monday, June 21, 2010 - 09:52 am:
Hi There,
Sorry ...not in my database
Try emailing
restoredclassic@aol.com
to see if they can help
Mention this forum
