SAFE 4 ON RADIO
Username: Paul73
Dublin, Ierland Ireland
hi all, dose anyone no how long you have to wait when your radio ses
safe 4 on the display , just got me code today for opel vdo seimans
thanks paul
Username: Paul73
help meeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee}
Username: Hay88
Post Number: 727
To give you some idea of how long you'll have to wait before you can attempt re-entering the code if you do get it wrong:- (and by wait, that means having to leave the key in the ignition, turned to position one, and the stereo switched on as well)
Attempt 1 - wait 10 secs. (Display shows 10SAFE)
Attempt 2 - wait 10 secs. (Display shows 9SAFE)
Attempt 3 - wait 10 mins. (Display shows 8SAFE)
Attempt 4 - wait 20 mins. (Display shows 7SAFE)
Attempt 5 - wait 40 mins. (Display shows 6SAFE)
Attempt 6 - wait 80 mins. (1 hr 20 mins) (Display shows 5SAFE)
Attempt 7 - wait 160 mins. (2 hrs 40 mins) (Display shows 4SAFE)
Attempt 8 - wait 320 mins. (5 hrs 20 mins) (Display shows 3SAFE)
Attempt 9 - wait 640 mins. (10 hrs 40 mins) (Display shows 2SAFE)
Attempt 10 - Time for the bin. (Display shows 1SAFE)
Username: Paul73
thanks very much hay 88, so i dont have to leave the engine running then, i heard the radio turns off after an hour would this be right ,il leave it running for the 2 hours and 40 mins if that what it takes
Username: Hay88
Post Number: 730
yes thats right. not all turn them self off.
Username: Mohammads
BirminghamUnited Kingdom
I have lost code for vdo cdr 500 after a battery swap in a Vauxhall Vauxhall Astra LS DTI 16V ECO
s/n: GM050021542249
Your help would be much appreciated.
Thanks.
Username: Regrooster
Post Number: 3909
MohammadS
Username: Mohammads
Birmingham
United Kingdom
Posted on Friday, May 21, 2010 - 07:21 am:
s/n: GM050021542249
Thanks.
As has been stated many times on this forum the majority of SIEMENS/VDO codes (including your CDR500) will NOT be available for free (or cheap) from anywhere on the Internet as access is required to the original factory database...which is not commercially available..
Try your Main Dealer or a Decoding Service or your local Car Radio / Audio Shop (who are normally the cheapest option) who will connect it to a laptop to read/recode the memory chip (EEPROM)
