Car radio code philips sc201
Username: Kroimpa
Hi, just got me car :D
But i dont know the radio code
I hope u guys can hlp me out
Srial no: gm0102p1031533
460/75 S
93302WA00
Username: Kroimpa
Can someone help me out please ?
Username: Kroimpa
Am i doin somthing wrong? Is there info missing? :o
Username: Regrooster
Post Number: 3704
You are too impatient !
These requests are answered by volunteers !
If you are in such a rush , then try an on-line decode service who will provide the code by return.....for a fee
Username: Kroimpa
Srry dont want to look impatient, its just some people get allot of replys really quick, thought that i maybe forgot something.
Username: Damomcguinness
Malahide, Co Dublin Ireland
I changed the battery in my 1999 renault laguna and now I need the code to operate the radio. The codes on the back of the radio is RN481FW9040899 and 7700433070M738.
Many thanks.
Username: Hay88
Post Number: 626
Damomcguinness
your code 0555 how to enter below
IF YOU DONT HAVE KEY THEN PUSH THUMBWHEEL IN AND SOME HAVE {A} KEY
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ] button then rotate the thumb wheel for the correct first digit
Press the [ ] button then rotate the thumb wheel for the correct second digit
Press the [ ] button then rotate the thumb wheel for the correct third digit
Press the [ ] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ] button for up to 10 seconds to store the code
FOR NO STEERING CONTROL
press the first preset button for the 1st digit,
second button for the 2nd digit
third button for 3rd digit
forth button for 4th digit
then press buttons 6 OR 5 to store. for 10 seconds
note the radio does not lockout after a wrong code entry it only doubles the time to wait before
the next retry...if a wrong code is entered it will display error then after the delay should display "0000")
PayPal donations to my Code Calculator Software Fund are always most welcome
Donate link here: http://www.paypal.co.uk/uk
payments to: codehelp@hotmail.co.uk
Thanks a million. It worked. Driving will be so much better!! Cheers!
