Pioneer wiring harness question
Tony Kwong
Hi,
I currently have a Pioneer DEH-P6000 CD player in my car and plan on getting a newer Pioneer MP3 head unit. I was wondering if I can use the same existing wiring harness on a newer Pioneer deck. Or will I have to get a new wiring harness for the newer decks? I was wondering if all Pioneer CD players have the same wiring harnesses. Thanks for any help.
Adviser
Definitely not all Pioneer CD players has the same wiring harness.
You can check the wiring at the back to see if they are the same. Otherwise a little adjustment will do the trick
