Box build for Andrew
Username: Dustin3
Box Designer & Builder...Dustin
Post Number: 5451
Getting these pictures up a little late but this was a build that I finished for Andrew R. It is a sealed box for 2 10" RE SE's. Here are the pictures. The last picture is my official logo when my website gets up and running
Username: Deanerjr
Post Number: 237
very nice, how many Cu ft?
Username: Dustin3
Post Number: 5453
1.25 cubic feet.
Username: Andrewski
Dustin the box and craftsmanship is amazing!
I can't wait to test out my SE's now
Thank You very much!
Username: Rovin
1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 16120
came out quite nice
reminds me of the time i also did 2 10s RE SE sealed....
http://forums.trinituner.com/forums/viewtopic.php?t=200026&highlight=box+review
Username: Andrewski
Rovin I saw your thread and you're the reason I decided to go sealed
I hope my SE's will sound just as good as you say they do in a sealed enclosure
I decided not to go ported because I don't need them TOO loud but I wanted more punchy bass with better SQ
Username: Glasswolf
Columbia, SC USA
Post Number: 12708
two ideas for future builds.
If you inset the side panels maybe .5 to 1.00" on both sides, when you cover the box, the lip left will act as a handle to lift the box.
If you use a router to cut those holes for the subs, you can route an inset there, too, so the subs sit flush when they're mounted. It makes them look a little more professional when everything is done.
box looks great.
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 285
As always,a great,clean looking enclosure.
Username: Rovin
Post Number: 16121
oh i didnt know it inspired some1 to do the same which is no problem
if u port those SE's it will totally drown out ur front stage especially on those bass heavy songs but the sealed was used to match up with my front cdt stage
since my ride is a wagan the cabin gain definitely helps so i hope it works out well in ur case too
that was almost 2yrs ago & i still have my pair around even though i went with a 12" idmax around august last yr ....
Username: Dustin3
Post Number: 5455
Glasswolf ~
Yes I know. I do both insets or rabetting. I know you have been gone a while but I have had many build logs of different kinds of builds where I do everything from flush mount to insets. Thanks for the look out though!
And Rovin, yeah, Andrew was wanting a box that looked similar to yours
Username: Glasswolf
Columbia, SC USA
Post Number: 12709
yup didn't see the other threads.
Username: Dustin3
Post Number: 5462
Andrew. Just to let you know it will be shipped out tomorrow.
Diamond Member
Www.stainles... .ecrater.com
Post Number: 22557
I swear if I didn't know how to myself I would have you build my next box dude.
You are my brother in another life lol.
Nice job and PR.
Username: Dustin3
Post Number: 5463
lol. Thanks Paul, I take pride in all my builds :D
Username: Deanerjr
Post Number: 244
haha, i will take pride in your build for me, i trust yours more than mine
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 292
^lol I thought the same thing!
Username: Dustin3
Post Number: 5464
Thanks fellas!
Username: Rovin
Post Number: 16143
cant see any screws so do u use staples & a strong glue or do u putty over the screw holes ...
Username: Dustin3
Post Number: 5467
For smaller enclosures I use Titebond II and clamps (like this one) Rovin. Anything bigger I use screws and Titebond. I'v done many many experiments on the strength of titebond II and clamps and It's quite amazing how strong it actually is.
