Did i f*ck up
ive had my sytem for about a month now and today teh stopped working i decided they werent getting any juice...because the is a light that is usually on my amp and that wasnt on....so i decided to go buy a new fuse my fuse said 100A and i couldnt find one of them so i got a 60 i put it in and turned my car on and my amp started to smoke i only had my car on for like 2 seconds....did i mess anything up???\
Username: Rswan
Post Number: 148
you sure did
Username: Dan3
Post Number: 116
amp smoking? Eh, thats never good....
so i liked fried my amp or what??/
Username: Beligerant1
NC USA
Post Number: 14
Im not sure why the amp started smoking but i dont think it had anything to do with the smaller size fuse you put in. I might be confused but as far as I know the 60 amp fuse should burn up long before the 100 amp fuse would, thus the 60 amp is safer.
see that is what i thought...idk
Username: Grmncrsnbr
VA
Post Number: 83
was it an audiobahn? lol JK lets not turn this into a war
That sucks dude wish I could help
Username: Rswan
Post Number: 149
so your fuse didnt blow?
idk i thought the one i had in there blew so i tried to replace it with a 60 amp fuse instead of 100 amp fuse and the amp started to smoke
Username: Rswan
Post Number: 150
yeah, but did the 60 amp fuse blow?
Username: Jonathan_f
GA USA
Post Number: 661
Either way, the fuse isn't going to make the amp smoke. Take the amp wherever you got it from (or call tech support then mail it) and either get it repaired or replaced.
Username: Hx2eaglevision
Borger, Texas United States
What kind of amp was it?
my system consists of a pioneer deh 6600 head unit a jbl bp 1200.1 and 4 kicker comp vr 12
