Simple question
Username: Ceedeeohtee
WinterpegCanada
Post Number: 10
Sealed or ported? I'm more worried about SQ than SPL, is sealed the clear choice in this case?
Username: Philly306
If youre going to give...
Post Number: 1520
depends on the speaker
WinterpegCanada
Post Number: 11
Okay. Umm say type R's, W6's and W7's (I'm up in the air at the moment)
It's in a 4 door sedan (G8) if that matters.
Username: Philly306
Post Number: 1523
well again it depends on which speaker you choose. The response from each speaker is going to be different in identical enclosure alignments(i.e. sealed or ported)
Username: Nd4spd18
Philadelphia, PA
Post Number: 10918
The general rule is that it is easier to get better sq with a sealed box. However a porter box can be made to sound just as good and a bit louder but it must be designed tuned and built exactly right. If your not using a professional builder go sealed.
WinterpegCanada
Post Number: 12
Alright, now what if I'm getting a custom box made from say a place like Visions/Advance (audio/video store)?
