Need a double din for 2003 subaru
Username: Mattwood1000
i recently bought a new head unit which is a single din. the stock radio was a double din and therefore i have remaining room. i need help if any1 knows where i can find a spacer or sometihng to fill the space let me know
Username: Nick_belsky
North Canton, Ohio USA
Post Number: 76
Some of the Scosche and Metra kits have the dash kits that have a "pocket" option to fill in the space. You may want to look into swapping out the dash kit...or look into finding another piece of equipment to set in the DIN opening that is left
You could look for a single DIN spectrum analyzer that is compatible with your head unit, a "center" channel speaker will fit in there (made by Alpine), etc...
