HELP PLEASEE! THNX
Username: Ii_numa
Im just got my license and i have front and back alpine speakers, and i wanna put subs in. Now what do i need to have a "legit" system. Im not looking to spend too much money but just need to know what i need to have that nice bass in my car.
Username: Snowball123
West Allis, WI
Post Number: 3334
What is your max budget for everything?
Username: Hittin1
TEAM REVOLUTION, La. Lake Charles...
Post Number: 4149
Get a 12" Alpine Type-R and a little ~500 wrms amp in a ported enclosure and bass away..
Username: Rovin
1 15 = 152.5 DBs ...Trinidad & T...
Post Number: 15662
^^^yep i like that idea - full alpine ...
Username: Skdooley
Roanoke, VA Usa
Post Number: 126
Yeah I was thinking alpine type Rs as well. Affordable and all matching brands. x3 here.
Username: Brewsky
Victoria, British colu... Canada
Post Number: 234
if u got a couple hundred look for capps board for his bl 12 and rd1000.1 290 shipped and it will pound!
Username: Ii_numa
well if i get a 500 amp, what brand?
Username: Skdooley
Roanoke, VA Usa
Post Number: 127
Depends on if you'll be running at a 2 ohm load or 1 ohm. What price do you want to stay around for an amp?
Username: Ii_numa
something not too pricey, but also something good, or at least decent. Ik alot about subs and the sub boxes, but idk anything about amps haha.
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 176
If you do go with the type r 12 get a dual 4ohm,an match it with this. http://www.onlinecarstereo.com/CarAudio/p_19251_Alpine_MRP-M500.aspx
Username: Ii_numa
ok thnks. but gotta question, one of my friends said get one subwoofer and one sub box, and my other friend said get a double box and two subs. which is better? i was thinkin the double both obvi haha
Username: Brewsky
Post Number: 236
ok what u need to do is tell us your price range lol and how much area u have to work with u can always make more noise from a custom box prefab sucks :-) way to many variables
Username: Ii_numa
well all together around $500 or less
Username: Jbpitt
Pittsburgh, Pa. Usa
Post Number: 178
Is that $500 for the subs,amp,wiring,and box?
Username: Ii_numa
500 for subs, box, and amp
Username: Ridinspinnas
Windsor, Ontario Canada
Post Number: 530
you can get a decent system for that, id stay with a single 12, instead of 2, save cost on quanity. make sure you buy good wire, and a good amp. i like the idea of all alpine, reliable equipment.
Username: Ii_numa
Post Number: 7
ok. will there be any difference with having one sub compared to 2 subs? Or is it just the same basically.
Username: Rovin
Post Number: 15676
if u mean 1 500wrms vs 2 500wrms sub
obviously it will be double output\loudness
BUT obviously too u will need a amp thats puts out double power , double the box as well & u may need to upgrade ur alternator
IF u mean instead of a single 500wrms sub OR 2 250wrms sub it will be a little bit more otput but double the amt of box space occupied
IMHO : stick with the 1 12 type R set , in the right box it can get more than enough loud for a daily set
http://onlinecarstereo.com/CarAudio/p_14954_Alpine_SWR-1242D.aspx
with a
http://onlinecarstereo.com/CarAudio/p_19251_Alpine_MRP-M500.aspx
ebay shud have it cheaper too
& thats a nice budget set which will sound good ...
